Results 1 to 7 of 7
Thread: Tow-Ster
    Tow-Ster
    Anyone have experience with one of these?
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    Pismo Beach, CA
    Yup.... I've owned one since 1974.... ..
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Good one Lew!
    -Albert Eienstein
    i remember seeing these many years ago, but not such a nice design.
    this would be ideal for taking your bike to the shop. it would be important to check the tongue weight rating of your hitch to make sure there aren't any -uh-oh's... but i doubt a bike would exceed the rating.
    i've not used one, but it looks very well built.
    ian
    __________________________________________________ ________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e || '07 Xchallenge || '14 Grom
    Pismo Beach, CA
    I am, if nothing else, a wise ass!!! In case you weren't absolutely sure.. ..
    YouTube demo:
    http://www.youtube.com/watch?v=3z_yoVrGa0g
    I think this Tow-ster thing would be great for short hauling, as mentioned, to the shop as long as it wasn't too far away... 20-30 miles maybe? In fact the video states that it is a piece of "emergency equipment".
    I don't think it would be so good for hauling off on a five hundred mile trip. Arguably the two tires normally share the weight of the motorcycle, but loading up the back tire seems like it would be subjecting it to uneven wear (of the tire, and the mechanical components).
    Another issue to consider (for long or short hauling) is that there are no functioning tail lights on the bike. The tow vehicles tail lights are unobscured, but most states require that a towed vehicle be equipped with functioning lights... With no rider on board it isn't too much of a stretch to imagine some dolt rear-ending your scooter "because I didn't see the motorcycle!"
    Lew Morris
    1963 Dnepr
    Sep 2009
    SW, MO
    I made one of these many years ago out of necessity when moving from Calif. to Colo.
    Mine however had a hole for the front axle to fit through, and necessitated the removal of the front wheel. The forks slipped down on the inside, and the axle went through to secure it.
    By the way, don't believe that carp about backing it up!! lol
    460
    -Albert Eienstein
    dstuckmann
    Good idea. Maybe notǪ
    I called Toe-Ster and got some info. Its made for a 2 receiver (Class III) and they determine the tongue weight by using 2/3 of the bikes weight. So a 700 pound bike would equal a 469 tongue weight. Add the weight of the Toe-Ster and the hold downs and you would most likely be at the limit for a Class III hitch.
    Couple of things to consider here.
    Class III hitch is rated for 500 lbs tongue weight. That is based on the fact that weight is applied at the ball location, which is close to the receiver. The Toe-Ster looks like it may place the load 1-2 farther back on the hitch. This additional leverage would add a lot of strain to the hitch and possibly the tow vehicle itself. If using adaptors to connect it to a Class II would most likely move this lever even further back.
    Here is a big one. How is the bikes transmission lubricated? If the transmission is separate from the crankcase, it may have splash lubrication, which may be fine. However, common case (especially dry sump) systems most likely have forced lubrication to the gears, shafts and bearings. Check your manual to see if it can be towed.
    Even if these obstacles were cleared, I still would not buy one. Id put the money towards a good used flat trailer that would have multiple uses.
