Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 55
Thread: Low temps = lower traction, and a low side!
  1. #16
    Quote Originally Posted by BCKRIDER View Post
    Very interesting! Any explanation how the "cold" tire could register only 20 degrees when the pavement was 27 and the air temp about 35? I would have thought that tire temp, after sitting long enough, would equal the air temp.
    This was exactly my thought too. Weird.
    Tom - MOA #156706, Hayward, CA
    2006 BMW R1200GS Adventure, aka "Gretel"
    1983 Honda V65 Magna - SOLD
    http://www.flyv65.com
  2. #17
    Registered User texanrt's Avatar
    Nov 2008
    Lafayette LA
    Quote Originally Posted by r80rtjohnny View Post
    very glad to hear that you are ok and providing us with all this information. This really has the makings of a good article for next fall's on. Great stuff - tire temps, road temps etc...
    +1
    John H | TexanRT | Lafayette | IBA
    BMW R1200RT '09 | Honda Goldwing '12
  3. #18
    Jun 2005
    Green Bay, WI
    Hopefully I can get some tire temperature explanations from the tire makers. Maybe they can explain that weird temperature differential from the surface, air temp and tire surface temp. I would think that being black, the tire would naturally have the same or even slightly higher temperature than the air temp.
    Next time I'm in the shop I'll point that same infrared temp reader at the underside of my tongue and see if it calibrates to 98.6 degrees. I should have done that before checking any other values just to see if the gauge was accurate to begin with.
  4. #19
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by ANDYVH View Post
    That's true. Our cars have TPM and when parked facing east or west on a sunny day, the tires on the south side of the cars will read several degrees higher than the north ones.
    Lee
    2016 R1200RS
    MOA # 30878
  5. #20
    Feb 2010
    Colorado
    Temperature differences
    I'm a product of the Tennessee public school system, so this could be all wrong.
    Could the temperature differences between surface, air and tire be due to wind chill?
    At an ambient air temp of 35 degrees with a 60 mph wind (or for a tire travelling down the road at 60 mph), the wind chill is 17. So, the tire surface is cooled from the "wind chill" affect. The tread in contact with the road (middle) starts to warm first from the friction, but the tread on the side could still be cold from the wind speed.
    Just a guess.
    piperjim
    Piperjim
    '95 R1100RS "Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" Henry Ford
  6. #21
    May 2003
    SW Iowa
    Quote Originally Posted by piperjim View Post
    No, wind chill does not affect tires, machinery, ect.
    Windchill factor is what the skin feels.
    If you take a temp. reading of a piece of machinery in calm air at -10 deg. the reading will be -10 deg.
    If the wind is blowing and the temp. is -10 deg. the temp. of the piece of equipment is still -10 deg.
    Lee
    2016 R1200RS
    MOA # 30878
  7. #22
    Jun 2005
    Green Bay, WI
    Right, Wind Chill is what humans and mammals feel due to the cooling effect of the moisture in the air, on our skin, and how the wind has the ability to strip away the boundary layer of warm air just off our skin, of trapped in our clothing.
    But it still baffles me that my tires were considerably cooler than the air temp. Even after sitting for maybe 45 minutes after my low-side ride. Assuming my tires had warmed (on the surface at least) to about 55 or 60 degrees, within those 45 minutes the front tire surface had cooled to less than air temp. That leads me to think the air in the tire, was never as warm as the tread surface aven after 20 miles of riding. After the ride, the thin heated layer on the tread surface was quickly displaced through conduction of the colder temperature inside the tire.
    Plus the cooler air volume/tire surface area inside the tire is much greater than the much smaller surface area on the center of the tread. The more I think of this, the more I think it takes much longer than we think to totally warm up cold tires. The other correlation the tire makers may help with is how long it takes for the tire pressure to increase a few degrees as the tire totally warms up.
  8. #23
    May 2003
    SW Iowa
    I live approx. two miles from work and I can see a one to two PSI increase on my car tires with the TPM display.
    Lee
    2016 R1200RS
    MOA # 30878
  9. #24
    Andy, thanks for being willing to share your experience for the benefit of others.
    As for the temperature discrepancy, it will be interesting to see how your tests of the thermometer turn out. The specific heat of air is very low compared to rubber so I doubt if the air in the tire was much, if any, cooler than the rubber....unless the rubber wasn't heated all the way through. Still, that wouldn't explain a tire temp less than the ambient air and pavement around it.
    Anyway, thanks again for sharing and I agree with the posters who'd like to see this in the News.
  10. #25
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    I'm inclined to agree with piperjim (post #21) and disagree with Lee (post #22.)
    Certainly, if you took a reading of anything inanimate which isn't being heated, the temperature should be the same standing still and moving 60 mph. But cold weather or hot, tires ARE warmed up by friction with the road and also flexing as they respond to a less than perfectly smooth road surface.
    So it makes sense to me (assuming you started with the same "cold" tire pressure at both 40 degrees and 80 degrees) that the friction with the road and flexing should be very similar. The reason tires are slower to warm up in cold weather - and I would guess NEVER reach the same rubber temperature as in summer - is due to both the cold surface of the road AND that cold air moving past the tires. I don't think we should be too quick to dismiss "wind chill" as a factor. And then, another disturbing thought occured to me.
    In Canada there has been a lot of publicity encouraging people to get winter tires for their vehicles, even in areas where snow is rarely a problem. (US too?) The reason given is that "all-season" tires have much reduced traction, even on bare dry roads, when the temp gets to about 40 F. The tread gets too hard and doesn't have enough "squirm" to give you nearly the control you had for stopping or turning in higher temperatures. "Winter" tires not only have the lugs for gripping snow; they also grip the road better in wet and/or cold or icy conditions.
    Could this apply to bikes too, especially "rounders" who do not fear rain or cold?
    To the OP - thank you. You have opened up a much wider discussion than you could possibly have imagined. There is clearly a lot to be learned about cold weather traction. Maybe your submission - and all the responses it has and will receive - will help a number of riders avoid an accident. And I agree you should write a motosafe article for the ON. Get more reaction to this thread first before you write a column.
    Then do it!
    Doug
    1992 K100RS
  11. #26
    Feb 2010
    Colorado
    Tire/traction/temperature info for Police Bikers
    I found this posting on a Suzuki forum, and it was credited to a police bikers forum.
    "By Lt. L.P. Walker
    This is a notice to all motor officers, and especially those who may not have experienced much cold-weather riding. Motorcycle tires and pavement interact differently at colder temperatures giving a rider less traction than he would have in warmer weather. Its good to remember that riding in cold weather is roughly the same as riding in wet weather.
    Colder temperatures affect the rubber compounds in motorcycle tires by making them more rigid and less flexible than they are in warmer weather. This means that the tire has a weaker grip on the roadway surface. Of course the center part of the tire will heat up after a few minutes of riding and give more adhesion, but the edges of the tire that do not contact the surface during normal straight-ahead riding remain colder than the rest of the tire. During tight turns, these cold edges contact the pavement and can lose traction against the cold pavement and cause a front wheel slip that can be disastrous to the rider. In temperatures in the 30s and below, this becomes much more pronounced.
    Its good to remember that cold tires against cold pavement can cause a situation similar to riding on wet pavement. So treat colder weather the same as you would wet weather, and remember to ride safe."
    And, from a moderator on a physics forum:
    "Cold tires are stiffer. Thus they do not flex as much as they would when the weather is hot. Less flex when rolling in a straight line means less heat generated in the core of the tire and thus less heat on the edges. So edges remain colder in cold weather not simply because of convective cooling from the cold air, but also due to lack of flexing of the carcass, which is one of the primary causes of tire heating. every time the tire rolls into its contact patch, the tire flattens, and this bends the tire shape from round to flat at that point and causes tire heating. Added to the cold tire stiffness causing lack of flexing is the cold tread temp having much less grip. This will depend on the compound of the tire, with summer tires providing much less grip at cold temps than tires with a more all-temperature compound."
    I'm suspect that we could keep a few physicists and chemists busy on this question for the rest of the winter!!!
    Indeed, fertile ground for a future ON article!!!
    piperjim
    Piperjim
  12. #27
    Wind chill is all about perceived temperatures. Tires don't perceive! Tires may not get as warm in the wind and they will cool to ambient temperature faster in the wind, but they will not fall below ambient regardless of the amount of wind.
  13. #28
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    Bottom line: there is a point especially in cold weather (<3C) where there is no snow on the road to give you traction that sand, chemicals, black ice, frost, debris etc when one is taking a risk on two wheels. We all have a different tolerance to that risk but it is real. As someone who has not gone down in one of these situations on a street bike - I make a decision each season when to stop riding because there are far more uncontrollable things than controllable things. I find the science helpful and interesting to know why and how but when certain conditions exist on pavement - one will go down - no matter how expert. I know this may be controversial but cold conditions on pavement and the extreme variablity of weather and road surface issues (most of which canNOT be seen) is truly treacherous and unpredictable.
    Cold weather riding on dirt and gravel with a bike tires made for it (including studs) extends the season right through winter most places in the world.
    Ride safe.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
  14. #29
    On the road again! R80RTJohnny's Avatar
    Ottawa, Ontario, Canada
    Quote Originally Posted by bogthebasher View Post
    Ride safe.
    Very interesting point. Where I live there are two factors that I take into consideration when putting away the bikes. The first is temperature - <3C is just about right (daytime high as this would equal -5C overnight). The second is when they start with the salt and the sand on the roads.
    And let's not get started on the roads that are shaded and those that are warmed up by the sun. In cold temps this can prove quite "exciting" especially if there is some water run-off.
    2008 R12RT (Blue)
    1986 R80RT (Silver)
    Member of the Loonie-Tics. MOA 292.
  15. #30
    Cal
    Nov 2003
    Suches, Ga
    A friend a long time ago told me that in the old days of motorcycle racing they lowered their air pressure in order to allow the tire pressure to come up to working temperatures and expanding the air inside without risk of decreasing rolling resistance due to having an over inflated tire.
    I ride in the GA mtns during the winter and what I do is just that. I ride an '05 GS according to BMW recommended tire pressure is 32 front 36 rear so I lower them 2-3 lbs and find that my bike/tires grip better.
    Just my two cents but then it could only be one.
    Cal
