Results 1 to 4 of 4
Thread: Oil indicator that's not shown in the manual?
    Apr 2006
    Nibley, UT USA
    2010 K1300GT (in stunning Apple Red!) with 1k miles.
    600mi service was done at 670 miles. Have had NO problems thus far with the bike but today went for a 100mi ride and on the return trip had an "Oil" indicator show up as I cycled through the TPS, Temp, etc. on the computer. The indicator just says "Oil" with a check mark behind it. I took this to mean the oil level needed checking, so stopped twice on the way home and put the bike on the centerstand, ran it for a minute or so, then shut it off and checked the dipstick. Both times the level showed at or slightly above the MAX mark, and after letting the bike sit for 10 minutes or so in the garage that's where the level is still showing. I called the dealer but didn't get to talk to the main service writer. The person I talked to said to reset the computer by starting the bike, revving the throttle twice then turning off the key.
    Anyway, I'm still seeing the indicator on the dash. Mind you, this is not the indicator or the check engine light, it's just something that appeared in the rotation along with Temp, TPS, MPG, etc. etc.
    Anyone see this before? What's the skinny??
    Thanks,
    GTRider
    Jul 2005
    Colorado
    Look in the manual that came with the bike. Page 58, I think. It explains that the check mark means "ok" after the bike is warmed up.
    Greg
    Apr 2006
    Nibley, UT USA
    Doh!
    Found that about an hour after I posted. It's in a different section of the manual than the other indicators, where I was looking. What gets me is that the service guys didn't have that answer right off when I called them. Goes to show that there's too many bells and whistles and switches, I guess. I'd trade a lot of the electronic displaying and nagging for a good Stebel horn, for example..
    Thanks,
    GTTRider
    Aug 2008
    Kingston, NH
    Quote Originally Posted by GTRider View Post
    Thanks,
    GTTRider
    hey you can put one in yourself if you're interested
    Click Here
    2009 G450X White
    IBA #35651
    Rogue Moderator
