Results 1 to 6 of 6
Thread: GPS mount
    GPS mount
    Trying to mount a Garmin Nuvi someplace other than suction cupped to the gas tank. Any ideas? I'm on an R1150RT and would like to mount it closer to the wind shield so I can see it without looking away from the road. Thanks group. James
    Tame Racing Driver Stig's Avatar
    Dec 2009
    Hudson Valley, NY
    Check out Migsel GPS mounts. I have my Nuvi mounted on one on my RT and have been very pleased with it. A bit spendy due to the exchange rates, but very well made and no permanent modifications required. I also like that you can add 2 more RAM arms for a total of 3 mounts up by your line of sight.
    $.02
    Craig
    New York's Hudson Valley Region
    2009 R1200RT
    MOA #146131 IBA #55715
    Registered User clowry's Avatar
    Sep 2006
    Oakville, ON
    Check out Cyclegadgets.com. They should be able to fix you up with everything you need.
    Sheboygan, WI
    Smile
    I have a Garmin Nuvi 350 mounted on my R1200RT, using a RAM system mount.
    My mounting ball is atop the clutch resovoir - just one of many RAM options available to you.
    Good Luck!
    http://www.ram-mount.com/
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    I went with the Migsel mount for my 1200RT. It is a bit pricey, but it is much more stable than the shelf I was using.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Arrow
    Check out the following Link
    http://forums.bmwmoa.org/showthread....light=jakfrost
    This is the unit I installed on my 1100RT......with a Big Mak map case tank bag I use a 5" Ram Mount Extension arm which holds the carrier for the Garmin 2720 GPS which I use........The system is great and is easily removed for storage /security. The center mounting position makes for an unobstucted veiw of the gps
