Results 1 to 6 of 6
Thread: Final Drive issues
    On the Road
    Jul 2010
    Final Drive issues
    I was looking at the final drive failure data......
    I am a noob...what would explain the final drive failures on the 1200LTs? Seems as though they might dominate the drive grave yard.
    Two up riding, extra weight, continuous speed driving?????
    What is the BMW line on this.....? what say yee LT riders?
    On the Road
    Jul 2010
    Think this issue is getting covered well enough on previous thread.......sorry about being redundant
    Registered User rmcclure's Avatar
    Dec 2009
    Erin, Ontario
    One possible problem area is Dunlop tires sized for the K1200LT seem to have
    a bit of swingarm interference in their fit. When I bought the bike used (92,000 km) this was noted, as well as this year when Metzlers couldn't be found when it came time to replace the tires, and I was forced to go with Dunlop again.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by rmcclure View Post
    There is a shim ring available that goes between the wheel and the hub to space the wheel a hair to the left, often (but not always) curing the Dunlop clearance problem.
    Mark Neblett
    Fairfax, VA
    #32806
    Dec 2009
    Erin, Ontario
    Where is this shim ring available? Is it dealer or aftermarket? It probably wouldn't take much as the interference appears more as a slight polishing of the right side of the tire at the edge of the tread, showing up after some harder riding, rather than as a real hard rub. It sounds like that might be just the answer for what I have run into.
    Nov 2005
    Fairfax, VA
    It's shown in the MaxBMW fiche here: http://www.maxbmwmotorcycles.com/fic...7&rnd=03192010
    part # 36311451791 SHIM - 2,000MM [2.0 millimeter] $6.71
    Mark Neblett
    Fairfax, VA
    #32806
