Results 1 to 3 of 3
Thread: r90/6 diode board
    Registered User MTHelmet's Avatar
    Danielsville, PA
    Unhappy r90/6 diode board
    I putting the bike back together after being apart for 3 years.
    My question is about wiring the diode board. On the back is two spade contacts. one is vertical the othe is horizal,. I have only one wire for the back which terminal get the wire.
    MT helmet
    [COLOR=Red]NO ONE ELSE ADMITS IT[FONT=Courier New]
    Loose Cannon flash412's Avatar
    Northern Colorado
    Take a good hard look at the diode board. You will see marks on one of the spade connectors where the wire used to be connected that are not on the other connector. If memory serves me well, if you look at the connectors and their traces on the circuit board, they are electrically connected to the same point anyway. (Unfortunately I cannot verify this right now as I am 1400 miles from my garage.)
    Click here for Tales of Motorcycles and Life
    - BMW MOA Lifetime Member #18854
    Danielsville, PA
    Thanks, I will have a look at the DB to check .
    MT helmet
