Results 16 to 27 of 27
Thread: Scorpion EXO-900 Transformer
    My experience with Scorpion was quite different - after 20 years loyal to Shoei I bought a new EXO-700 last fall and am exceedingly happy with it. I did however manage to catch the rear vent piece on a table edge and knock it off. I called and talked to the Scorpion folks and asked if they sold just that rear piece - instead they just promised to send me a new one gratis. It showed up 2 days later with the glue tape needed to affix it. So far I am pretty happy with Scorpion and the helmet.
    Ted
    1994 K75RT
    Moto Pages
    Hooligan
    Sep 2010
    Chattanooga, TN
    Scorpions are good helmets. Its just that all heads are not shaped similar. I use a 700 and am quite happy except for the wind noise inside.
    If anyone here had a 700 and was happy, upgraded to a 900 and have less noise, I wanna hear. I would like to buy a 900 if that were the case.
    warredon
    Quote Originally Posted by aviator View Post
    Are you using an Aero Skirt with the EXO-700? I installed one in mine a couple of years ago and it seems to help with the wind noise problem. I don't know how well the EXO-900 or the EXO-1000 would fit my head, but I can't say enough good things about their 700.
    Registered User TomDac's Avatar
    I have a Scorpion EXO-1000 and have been very pleased with fit, finish features and comfort of the helmet. Love the internal visor.
    Tom - MOA #156706, Hayward, CA
    2006 BMW R1200GS Adventure, aka "Gretel"
    1983 Honda V65 Magna - SOLD
    http://www.flyv65.com
    Jack Herbst
    Jan 2008
    Oro Valley, AZ
    Quote Originally Posted by TomDac View Post
    How long have you had the Helmet? How many times have you worn it?
    After pointing out the delamination around 3/4 of the bottom of the helmet to the factory rep. in PHX I returned home to Tucson. Now the entire bottom of the helmet dropped off. This is the third time I had worn it?????
    Jack
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    I have an EXO 1000. If it fit me better, I would love it, but my long head gets a pain right at the front peak. It has held up very well, with no issues at all. It is about 18 months old. I am going to replace it though, as the more I wear it, the more it hurts. It isn't the helmet's fault though, my head is just long.
    An excellent way to remove some of the shell foam to make a helmet with a pressure point more comfortable it to use 200-grit sandpaper - remove the liner and then sand at the pressure point a little at a time until it is comfortable. Do not take a ball peen hammer to it or otherwise compact it, compacting the foam removes its ability to protect your head.
    Jack - sounds like you got a lemon! I would call Scorpion and ask for a replacement. They will probably tell you to return it with the receipt to a Scorpion dealer (preferably where you bought it).
    Ted
    1994 K75RT
    Moto Pages
    Jack Herbst
    Jan 2008
    Oro Valley, AZ
    Quote Originally Posted by Ted View Post
    Ted the dealer has wiped his hands and is no longer carrying the Scorpian line (PHX). The factory rep has promised a new helmet. I am waiting as he said the factory will send it soon. The rep. took pictures and sent them to the principles. I am sure they will be somewhat shocked. The helmet is new. Only third time I wore it.
    Jack
    South Carolina
    I think they will probably follow threw on a new Helmet. Bad reports travel fast. My wife likes her 700. The only issue is its hard for her to put her glasses on. There doesn't seem to be enough room on the sides...
    AKA SNAPGADGET
    Quote Originally Posted by jaherbst View Post
    Jack
    I bought the helmet in the fall of 2007, shortly after it was introduced. - and it was very hard to find... limited early production and lots of demand, from what I read.
    It was by far the most comfortable helmet I tried on. I have worn it HUNDREDS of times since. I live in CA, so try to ride year round as much as I can - sometimes just to work and back.. or weekend day-trips.. or multi-day rides.
    It's held up nicely and still is very comfortable.
  11. #26
    No bugs in winter OHScot's Avatar
    Southwest Ohio
    I have the EXO 1000 and after 2 years of OK, apparently my head shrunk. Replaced the Large liner with the Medium liner now it fits the same as it did when new. $34.95 for resizing. I guess its OK.
    Vents are still not as good as my old Shoei RF 900 which still fits after 6 years.
    "Wow I didn't know BMW made motorcycles, Yeah I think Honda does too."
  12. #27
    Apr 2010
    Western MA
    My EXO-900 was a tad tight in the crown when I bought it. I figured it would wear in a bit over time and fit like a glove. Well that didn't happen -- as it turned out, I was at the top end of the XL fit. The remedy was to purchase the XXL liner/cheek pads and insert them in the XL shell. Note that the XL and XXL shells are identical in size/shape; the only difference is the liners/pads.
    Now, the helmet fits well and is nearly as quiet behind the RT as my CL-SP or my IS-16. The only problem I have now is the weight. The EXO-900 weighs just under a pound more than my HJC IS-16, making me feel a bit bobble-headed after several hours! Otherwise, I've had absolutely zero quality/durability problems with the EXO-900.
    Theo
