Results 1 to 5 of 5
Thread: Electrical Goofs Fixed?
Hybrid View
    Wilmington, NC
    Anybody happen to know if BMW finally got the accessory electrical stuff right on this one?
    Specifically, everything else in the line needs a fuse panel to run US heated gear for 2 because the factory outlets are limited to 10A for the ZFE.
    Repeating this goof would not exactly be intelligent design for something with pretensions to be the world class touring bike. A proper capacity set of accessory outlets (and maybe even a built in panel for other accessories) ought to be standard- its more useful than a lot of the other electrical stuff that will no doubt appear on this one.
    Aug 2008
    Kingston, NH
    That would be wonderful - of all the things I have read so far - that has not been mentioned, or I missed it
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Daily Rider jurgen's Avatar
    Red Rocks
    My first question is - will the alternator support two full sets of heated gear? That needs to be the case before you can discuss how to wire things up. The K1300GT is listed with a whopping 945W, the 2009 K1200LT had 840 W. Hope BMW got this one right....
    J?rgen
    Red Rocks
    04 R1150GS adv
    04 K1200RS last of the great bricks
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by jurgen View Post
    Let's see -- assume high heated gear use: 15A/person? (30A total)
    30Ax12V=360W 580W-360W=220W
    Assume 150W bike basic loads (ignition, lights, etc.). That still leaves 70W (6A) to spare -- in the face of a *massive* heated gear load.
    Doesn't sound like a huge problem to me.
    Mark Neblett
    Fairfax, VA
    #32806
    Wilmington, NC
    Indeed. Alternator capacity is NOT an issue on any of the current road bikes of the K and R series- they make as much as many cars and plenty to power anything you might want on a bike short of it being a substitute for a 110V outlet so you can use your microwave or hair dryer.
    Built in inverter for about 400W, anyone? Just in case you keep a TV or full size pc in a towed trailer?
