Results 1 to 9 of 9
Thread: oil filter crossover number K1200 s
    Apr 2008
    Waikoloa, Hawaii
    I was wondering if anyone had any crossover number for oil filter or any other parts. Thanks Woody
    Aug 2008
    Kingston, NH
    Mann makes the filters for BMW - you may want to check there
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Nov 2005
    Lancaster County, PA
    HIFLO Filtro HF164
    GREGFUESS
    K&N Filters
    makes something for the K1200S. costs the same as the BMW filter. It is easier to install and remove, as it has a nut welded to the bottom of the filter. If you do not have a $100 BMW oil filter already, the K&N would be worth considering for this feature alone.
    The $15 oil filter wrenches do not fit the wedge K1200S. Only the authentic BMW wrench, which is priced at $100 will fit. Since I already have the wrench before realizing that K&N only needed a socket wrench, I stick with the BMW filters.
    Sep 2006
    Quote Originally Posted by gregfuess View Post
    this oil filter set of pliers works great on Wedge engines.Available in most auto parts tools section
    see post 7 ...I couldn't attach the pic a second time
    http://forums.bmwmoa.org/showthread.php?t=43776
    Steve Henson
    GREGFUESS
    That's a pretty sweet wrench, wish I had checked here before getting the BMW wrench.
    Apr 2008
    Waikoloa, Hawaii
    Hi; you can use a rubber strap wrench to remove filter. I ALSO HAVE AN FILTER RING FOR MY HONDA THAT i WILL SEE IF IT WORKS, IT HAS A 3/8 DRIVE SQUARE HOLE FOR A EXTENTION ON IT. WHAT I AM LOOKING FOR IS A NAPA, PURALATOR, FRAM OR OTHER POPULAR FILTER CROSSOVER NUMBER FOR THE OIL FILTER . THANKS WOODY
    Sep 2006
    Have not seen an option other that Mann or the Mann labeled BMW for the shorty filter. There are lots for Oilheads . John mentions one in post #3...HIFLO Filtro HF164 , I have no info on it
    Maybe a friend could send you some over from the mainland? BeemerBoneyard has decent prices, we buy in bulk!
    Steve Henson
    Registered User 119240's Avatar
    Apr 2006
    Cambridge,Ma
    AC/Delco: PF-53
    Motorcraft: FL-793
    WIX: 51348
    Fram: PH-6063 or 3614
    NAPA Gold: 1348
    Purolator Gold: L10241--
    K&N: 164 (yes, the make a super duty oil filter that fits it), $11 bucks at Advance Auto)
    SYNLUBE: FNS
    '91 K75S, '06 K1200S
    BMWMOA #119240
    YB # 1463
    NRA #154764753
