Results 1 to 10 of 10
Thread: Price of Valve job?
    Price of Valve job?
    Just for grins.....what do you think the price of a valve job on this bike would be? Dealer of course.......
    Nov 2005
    Fairfax, VA
    Better to ask this on the wedge-K forum -- appears to be the same basic work to get to the valves (including draing/refilling coolant) -- then it's only a few more valves to look at (24 vs.16) once you are in there.
    My guess: Get a wedge-K ballpark number, and add 10%.
    Mark Neblett
    Fairfax, VA
    #32806
    If not done due to a defect under warranty I doubt one would be needed any time soon. We've had 4 bikes go over 150,000 miles with no valve work needed and two go over 350,000 miles with no valve work needed. At least one more will get up to that 350,000 eventually but it does take time.
    Nov 2005
    Fairfax, VA
    Ah -- I thought he was talking about valve clearances.
    But my original guess still stands -- wedge-K + 10% (unless all the valves and guides need to be replaced, then the 50% more valves would make me go to +15% -- most of either the valve clearance or valve rehab jobs is labor (rehab has more parts costs, but the labor is so huge it won't shift the percentages *that* much)).
    Mark Neblett
    Fairfax, VA
    #32806
    Well now, I don't know what he meant. In normalspeak a valve job is regrinding or replacing seats and valves. A valve adjustment is adjusting the valves.
    I now suspect he meant adjusting the valves. And I agree - about the same as a K1200 or K1300 - it just depends on how many actually need to be adjusted.
    Sorry
    I was referring to a valve adjustment........so called routine maintaince visit at XXXX miles
    Since a valve check/adjustment of these bikes involves.
    1. Take off a whole bunch of stuff
    2. Take off the valve cover
    3. Check each valve clearance
    4. Change any that are out of spec - I think this means removing the cams on the 1200, 1300, and presumably the 1600. Put cams back on the bike.
    5. Put valve cover back on
    6. Put a whole bunch of stuff back on
    My guess is that in the whole process whether you are checking 16 or 12 doesn't make a huge difference - and however many need changing is pot luck.
    Probability theory would say that the odds are higher that at least one out of 16 will be off compared to at least one out of 12, but ....
    Given the sophistication of this bike my guess is that valve adjustments are a minor thing to worry about.
    On the road again! R80RTJohnny's Avatar
    Ottawa, Ontario, Canada
    Would their be 24 valves (6 cylinders/ 4 valves per).
    At any rate, for those who will enjoy this new bike, maintenance costs should not be too much of a financial burden.
    2008 R12RT (Blue)
    1986 R80RT (Silver)
    Member of the Loonie-Tics. MOA 292.
    Quote Originally Posted by R80RTJohnny View Post
    Yeah, I lost track thinking about that new Ducati V8 concept bike that probably would have 32 valves. But the principle is the same. All the work is getting to them to check them.
    Registered User Motodan's Avatar
    Dec 2007
    Midwest
    Actual cost.
    Just to check them would cost an arm. If they need adjusting then add a leg to that.
    MOA #46783
    2013 R1200GS
