Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 62
Thread: Streetlight won't change to green
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    I would be interested in how people deal with stop lights at intersections that don't change. These on-demand lights with the sensors in the pavement often don't "know" I'm waiting for a green light. I have a gizmo on the bike to trigger the light, but it doesn't always work. I hate waiting for a car to show up to change the light to green. It's so humiliating.
    criminaldesign
    I resort to running the red light.
    Your gizmo to alert the signals you are there will seldom work.
    Call the city or county responsible for maintaining the signals at that intersection and report the problem. The loop sensitivity needs to be adjusted. Note the time, date, and who you talked to. You might need the information later, because:
    When the signal fails to activate and no car comes along you are faced with several technically unlawful actions.
    1. Left turn on red.
    2. Lane change within the intersection.
    3. Right turn from the left lane.
    The only technically legal movement is to push the bike backwards until you can change lanes prior to being in the intersection, then proceed straight through on green.
    It is my personal opinion that the situation falls under the category of a signal malfunction which should be treated as a 4-way stop. However, I had a rather long argument on-line with a former LEO who's advice basically was "good luck with that" when the officer sees you.
    So call it in, call it in, call it in, call it in. Most public works departments actually do want their signals to work correctly.
    Sheboygan, WI
    Cool
    Quote Originally Posted by walterK75 View Post
    I sympathize with your frustration.
    There have been many anecdotal 'solutions' to this problem mentioned before on this forum, i.e. "specific placement of the bike over the coil, undercarriage magnets, touching down the side stand, pestering your DPW for adjustments to sensitivity, lucky charms, snake oil, phases of the moon, take your chances in court" and other such libations.
    Check first if you state actually allows you to violate the signal under a specific set of circumstances, as in the case now (actually since Fall of 2008) here in Wisconsin.
    If not, PM me with your e-mail and I'll send you the text of our State Statute that permits a motorcyclist to ignore the red light after certain precautions are met.
    Then, send a copy of it to your state legislators with a request that they too join the 21st Century of traffic laws.
    Port St. Lucie, FL
    Many of the loop sensors do not detect a motorcycle. Calling the local community responsible for their maintenance usually does not work. If it were a car it would get a response.
    In any case, most state codes allow you to proceed after waiting a normal time for the signal to change.
    More communities are going to the radar sensors. You can tell them by the camera like device mounted on a stalk above the signal posts or arms. These rarely fail.
    Toadmanor
    Here in Minnesota it is legal, on a motorcycle, to proceed through a red light after waiting for a time and ascertaining the intersection is clear.
    I have never been questioned as I do this often.
    Apr 2008
    SW Ohio
    I try to stop right on top of the cutout (usually a rectangle) for the sensor wire. That seems to work 99% of the time. If not I run the light.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Registered User lionlady's Avatar
    Apr 2006
    Forest, VA
    Put your bike at the intersection of as many pavement-sensor cutouts as possible. I've almost never had an issue with a sensor not recognizing my R1150R.
    I always stop with my cylinders over a crosswise cut, and the tires/wheels on a lengthwise cut.
    P
    Courage in women is often mistaken for insanity.
    R1150R Rockster, Limited Edition!
    BUDDINGGEEZER
    Quote Originally Posted by Greenwald View Post
    l
    Arkansas has this law.
    Ralph Sims
    l
    Glad you found that Kevin.
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    Georgia has this law as well. I find it very useful on my early commute to work, where it's just me and the crickets some mornings.
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW, 2004 R1150RS.
    Hooligan
    Sep 2010
    Chattanooga, TN
    I may be wrong here but have heard that it has something to do with "iron" or steel your car or vehicle has. More plastic and alum, you will not trip the field.
    Sheboygan, WI
    Thumbs up
    Quote Originally Posted by aviator View Post
    No - you're correct.
    It's all about causing a detectable disruption in a magnetic coil. It is not about weight. Not enough ferrous metal - no discernable disruption.
    Either need more metal or increased sensitivity.
    Sheboygan, WI
    Cool
    I take it Texas does not have this law?!
    I don't know. It has never been an issue here. Brewster County, in all 6,192 square miles does not have any traffic signals, let alone one with a protected left turn.
