Results 1 to 6 of 6
Thread: squealing from front brake at low speeds normal? 2005 R1200GS
    MasterChiefmas
    The front brake of the R1200GS I have squeals as I slow down, at say, < 15mph. Is that normal? I checked the pads and they look like they have plenty of wear left in them.
    Thanks!
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Yeah, some bikes do that. I don't know if it is because of the bike or because of the way the rider uses the brakes. Most of my BMWs going back to my R80RT have squealed at low speeds.
    You can remove the pads and use something like this on the back to temporarily stop the noise (Permatex Disc Brake Quiet). But it will start up again soon enough.
    Registered User LENRT1200ST's Avatar
    May 2006
    Sanderville, GA
    R1200gs, 2005
    I traded a R1200ST for my current ride due to issues w/ my aging body and discomforts associated w/ the ST foot peg and handlebar placement. Especially on longer trips.
    The GS had a "screech" when the front brake is applied from the very start. Two services since, and still have the noise. The ST never had this problem! I've asked my BMW master tech to look into it during two services. Result: It still screeches on slow, low speed stops. I assume it's not a problem, but it is annoying!
    I now use the rear brake for my final approach and aviod the strangled cat calls.
    Len
    MasterChiefmas
    Ok thanks for the replies! I just don't know what to expect as normal. The sound would make me wonder what was wrong on my other bike.
    Registered User rmarkr's Avatar
    Mar 2007
    Lowcountry
    Try a different brand of brake pad - some squeal and some don't.
    Mark
    "Of all the things I've lost, I miss my mind the most" Mark Twain
    Registered Loser SHAG's Avatar
    Bradford, Pa
    Service bulletin # 34-007-05 (037) Defect code 34 00 90 39 00 Retrofitting anti-squeal kit.
    Which is a set of rubberized washers washers to install on both front discs. This only applies to 2005 R12GS-R12ST and K12S and was done under warranty if a customer complained.
    Go like hell, You'll get there quicker
    05-GS Rock Red 92k miles
    2013 TW200
