Results 1 to 14 of 14
Thread: Here's a question
    Registered User womanridge's Avatar
    Jun 2007
    Milwaukee, Wisconsin
    Here's a question
    I have the BMW tank bag with the soft clear plastic map holder on the top. I've seen this happen on others. The clear plastic is turning yellow from, I suppose, exposure to the sun. Does anyone know if there is a product that will restore it to a clear condition? Is this problem something that can be corrected?
    Karen Jacobs
    Moderator
    2012 R 1200 RT
    MOA-133005, RA32109, IBA #37923
    Mansfield,MA
    Hi Karen, there are things like this http://www.westmarine.com/1/1/63959-...ation-kit.html but I haven't found a real cure. Even when I get it back to looking much better it seems to go back to yellow even faster. I am looking for a tank bag now and when I find one that will be suitable I will probably have a spare plastic made from Eisenglass with Velcro and swap them out as they go bad. Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Sheboygan, WI
    Cool
    Quote Originally Posted by womanridge View Post
    My 'solution' has been to use tank bags where the map case is modular.
    I have a Bags Connection bag on my R1200RT right now, and the map case attached to it on top. If ruined, it's $14 to replace!
    Available thru www.twistedthrottle.com
    Pismo Beach, CA
    Go to an automotive upholstery shop, one that does "convertible top" replacement.
    They're usually set up to make replacement rear windows, so they could probably replace your tank bag "window".
    Lew Morris
    1973 R75/5 - original owner
    Polarbear Polarbear's Avatar
    Clovis,CA
    Good tip I like:)
    That upholstery thing sounds like a winner. May well be too costly though, but my BMW Bag has the same ill fated map window thing going on. Nasty how they fade out in no time. My dealer actually asked me how OLD my bag was, as he was going to give me another bag! I think you may have an option to get a new bag, if its under a year old. Mine was not. Randy
    Jun 2007
    Quote Originally Posted by Polarbear View Post
    No such luck. I got it in a trade of some farkles I had from my old RT and couldn't use on my 2010.
    Thinking back, I used my Marsee tank bag for over 50k miles and didn't experience the yellowing issue. Must be that inferior Bavarian plastic, huh?
    Thanks Gary, Kevin and Lew for your wisdom. I appreciate all your suggestions.
    Karen Jacobs
    Moderator
    2012 R 1200 RT
    Jul 2007
    5/6 Asheville, NC 1/6 Adirondacks, NY
    Try a marine (boat) repair facility that does boat cover repairs. They have the material and know-how to replace the window.
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    This may sound stupid but here it is.
    Minimize the bags exposure to the sun if possible.
    Don't leave your bag outside if you store your bike outside at home.
    Take the bag inside on rides if you can once you reach your destination.
    This may lengthen the life of the "resin" film.
    Am I hearing a collective "DUH!"?
    Jun 2007
    Quote Originally Posted by wezul View Post
    Here's a 'duh' from me.
    Seriously, I park in a garage and "Usually, bring the bag in when I ride. At least when I stop for the day. I just think it's the type of plastic. (See my post re: my Marsee bag.)
    Karen Jacobs
    Moderator
    2012 R 1200 RT
    Dougger
    I don't have a tank bag, but I've rubbed toothpaste on my discolored plastic headlight protectors and it clears them up like new. Might give it a try.
    Meguiar's Mirror Glaze products work quite well on clear vinyl, from convertible top windows to tank bag windows. The #10 Polish restored my old 325iC window removing all the yellowing, also was quite handy at removing the transferred ink and residue on the inside of my own multivario bag window.
    Follow up with the #17 cleaner to make it really clear again.
    Since this is a bit of investment it helps to see if someone has it near you to try out. If you are anywhere near DC you are welcomed to mine.
    Ted
    1994 K75RT
    Moto Pages
    Astatula, FL
    Contact Linda here: http://www.customtankbags.com/
    Bob Weis
    '04 K12RS - Hannigan Hack
  13. 09-24-2010, 01:25 AM
  14. #13
    Jun 2007
    Thanks everyone for your ideas. Now all I have to do is get off this keyboard and try them.
    Karen Jacobs
    Moderator
    2012 R 1200 RT
  15. #14
    Prefers to play martinph's Avatar
    May 2005
    Armstrong, BC
    I have a BMW tank bag with the plastic map holder, I find it to small, so use Zip lock bags as map holders and just clip it on top of the bag. cheap and easy to use.
    Martin. BMW MOA Ambassador.17748
    BMW MOA Charter, Life member.
    Valley BMW Riders. British Columbia.
