Results 1 to 10 of 10
Thread: Which Powerlet adapter for GPS?
    MasterChiefmas
    So I'm trying to decide what solution to use to power my GPS. I figure I have 3 options for the powerlet:
    - Powerlet stubby to cigarette socket
    - Powerlet to 10" cable cigarette socket
    - Powerlet to Mini USB
    So the 2 cigarette options ahve the advantage of more flexibility and price, but disadvantage of more parts to power something. But mainly what would you suggest doing one or the other between the stubby and cable.
    The miniUSB has less parts, and will plug direct to the GPS, but of course less things it will power, and is a more expensive bit then the cig options.
    Any opinions on if any of these have a advantage over the others?
    Thanks!
    Sep 2009
    Las Vegas Baby!
    What bike and what GPS?
    The GS / GSA's have a plug already on the bike that works for Garmin's or at least the ZUMO series.
    RobStar
    I'm moving this over to gear since it isn't hexhead specific.
    HANG ON.................
    MasterChiefmas
    Well...I think it kinda is specific in that I don't care if the stubby connector is the best one when used with a G650 if it blocks the handle bars from turning on my bike due to the location of the socket. That's why I posted it there.
    But anyway...
    This would be for a 2005 R1200GS
    GPS is a Nuvi 780.
    Thanks!
    Registered User robsara's Avatar
    Dec 2009
    West Michigan
    Check to see if your Nuvi even charges with the mini-usb on a wall outlet.
    Mine doesn't. You have to push some sequence that i've forgotten to get it to take a charge off the wall, and it can't be used during.
    I don't have a 780 though so maybe it's not an issue with them.
    That said, I have a powerlet to 2 cigars going to the tankbag, one of the cigars going back out to the gps via the included gps cable, one of the cigars left to charge the phone.
    The stubby adapters don't seem like a clean install to me, big, ugly, etc.
    But if you don't have a bag to hide all the wire, long adapters are even worse!
    FWIW
    Rob R
    1994 K75 My first bike.
    Quote Originally Posted by MasterChiefmas View Post
    Then I'd strongly suggest including THAT information in the thread title.. or at the LEAST in the posting itself.
    Registered User LMIWA156120's Avatar
    Chicagoland
    Like Bob, I have the powerlet to 2 cigar outlet cable. I leave it plugged in all the time, with the cable run under the tupperware, and keep it coiled on top of the airbox under the seat (on a R1150RT). I just pop the seat and plug things in as needed or I can pull it out and stuff it into the tankbag.
    Loch Miwa
    Crestwood, IL
    2004 R1150RT
    MasterChiefmas
    Well, yes, I realize that now. This forum operates a differently in that regard then most others I've been on. My normal reaction is that it would be redundant to post something in the subject area and then also announce that it was in regards to that subject of the area. I now understand that's just how things are done here.
    BACKROAD.ADV
    Thanks!
    Are you considering the GPS mounting as pretty much permanent on the bike or ???.
    I prefer to hard wire to the bike. I have an aux fuse panel on the bike and wire to there. I also use a ram mount and touratech shock mount for the gps this way when I remove it its a clean removal of the gps and I can use it on other bikes and vehicles if I desire.
    Installing Fuse Block: Note-fuseblock is wired into the keyed ignition so that when key is off then all fuse block accessories are off-If you prefer you can hot wire to battery-your choice. This fuse block also provides a ground block providing you with not only power but a central source for grounding. Some people like that - and some don't.
    GPS Mount
    On My Other Bike (Using a second Ram and Touratech Mount. Note two pictures are from two different time periods
    This way there are no wires to fumble with its grab and go. Also have mounts for GPS in my cars an truck. This makes for quick swap out. (Note: I use the Touratech shock mount on my motorcycles since without it I have lost 3 earlier GPS units to internal damage cause by shock and vibration caused by hard off road use)
    Just shop for the proper aftermarket piece parts and you are ready to go.
    Just a though -this was one of my winter projects when I had the bike torn down and had good access to the battery, frame, and wiring bundles so I could do a good job of routing wires, etc.
    Good Luck
    Mike
    MasterChiefmas
    Hi,
    Thanks for the detailed posting! But no, no permanent mount for me. I move the GPS between my car and bikes. Plus, it's not a Zumo, so it's not water proof.
