Results 1 to 9 of 9
Thread: Tophat - New Style Wheel Spacer ?
    bostonmish
    I am rebuilding a /6 front wheel and need to replace the "tophat" spacers. The old ones have wear grooves from the seals and heavy pitting from corrosion.
    The PN I came up with is 36311230322. I got it from here: http://www.realoem.com/bmw/showparts...54&hg=36&fg=05
    The Tophat Spacer is item #5 in the diagram. BMW calls it a "Compression Ring"
    When the parts arrived, I thought there was some mistake. The new ones don't have the wide "hat brim" ...as seen in the photos. Both the old and new are 13mm long.
    Does anyone know whether the old type "wide brim" tophat spacer is still available? ...under another PN? ...or is the new one meant to supercede and replace the old style (end of story)?
    Michael Stoic
    bostonmish
    Another View
    John D'oh
    Aug 2006
    Close to Fort Worth Texas
    Top Hats more like caps now...
    The wide brim 'hat' has been replaced by the 77 on narrow brim. The part numbers are the same for early and late style so the wide brim hats have been superseded. The length is the important part. Think of the new ones as lighter in weight for better performance. It used to be called a ‘«£thrust sleeve‘«ō and it‘«÷s always had that part number.
    I took this wheel apart two weeks ago and found one of each...took me a minute to locate the picture...
    Mike V. #30064 30064's Avatar
    May 2006
    San Diego, CA
    Boston...
    The new style will be fine, I would put a very light coat of grease or oil on them and insert them with the brim to the inside or against the inner race of the bearing. I believe it can go in either way and sometimes I've heard debate about this. I really think it amounts to personal preference. Personally I like the brim on the inside of the seal.
    Mike V. / San Diego
    MOA#30064 / ABC#11027
    78 R100/7 [orig. owner] / 81 R65 [restored]
    ABC-MOA-AMA-VBMWMO / http://tinyurl.com/4df7hgs
    bostonmish
    Thanks guys! I appreciate you sharing your experience!!
    ...I've got the inner races in the freezer. Tomorrow I get to start putting things back in... now that I know my parts set is complete!
    Michael Stoic
    May 2006
    San Diego, CA
    Good luck with the installation. Keep us posted. I hope the outer races are chilling also. Looking forward to hearing about the pree-load procesure. Do you have some 0.02mm or 0.05mm shims in case you need them?
    Mike V. / San Diego
    bostonmish
    ...outer!
    I've got the Dave Ausherman's shim assortment. All I need are the sidecar rig preload specs. I just got another thread started on that topic...
    Michael Stoic
    kreece
    Shim assortment
    Where can you get Dave Ausherman shim assortment set? Did not mean to high jack the thread, but can't seem to find this info anywhere.
    Thanks,
    Ken
    bostonmish
    Quote Originally Posted by kreece View Post
    Thanks,
    Ken
    http://w6rec.com/duane/bmw/wheel_bearing/index.htm
    I made a mistake (it was late at night) it's Duane, not Dave. Sorry Mr. Ausherman.
