LED Turn Signals
fastdogs2
I just installed these on my R1200R:
http://www.weiserstore.com/store/in..._id=20&zenid=75a29f7a6c2cde43494617d7c34ccca7
They are a very easy install, just unscrew the clear lens, pop out the bulb housing, disconnect the two wires, insert a guide template, reconnect the wires up to the LED connectiions, screw the lens back on and you are good to go. Took me about 20 minutes to do all four, but I am not mechanically gifted.
I saw these on the ADV Rider forum and thought they would make a nice replacement to the original equipment.
The LED's are really bright, compared to the bulbs and give a different look, when viewed through the clear lens.
I have seen these mentioned on a number of forums
unfortunately, they don't make ones for the R1150's. :banghead
fastdogs2, I also installed a set of these led inserts on my 2010 R1200GS. Like you said completely the most easy to install incredibly useful upgrade Ive done so far. The LED's are SOO much brighter than the stock bulbs.
