Results 1 to 10 of 10
Thread: Timing chain help
    Feb 2009
    Chicago, IL
    Timing chain help
    I'm in the middle of replacing my timing chain and after cutting the old one, I did something stupid and got the sprockets all misaligned. I can turn the crank fine by bumping the wheel but I can't seem to move the cam sprocket to get it aligned again. Is there a trick to this? What am I doing wrong? Many thanks for any help.
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    Grasping at straws here a bit, but have you loosen the adjuster nuts on the valves to remove the tension? I would think that would make it easier to rotate the CAM shaft.
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Registered User skiteach's Avatar
    Woodbury Ct
    Quote Originally Posted by 88bmwJeff View Post
    Safest way I can think of!
    '73 R75/5
    Never had a bad day skiing!
    Feb 2009
    Chicago, IL
    I did loosen the adjuster nuts on the valves and that created some free play but not enough to spin it the 180 degrees it needs to go.
    Woodbury Ct
    Rocker arm removal.
    '73 R75/5
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by skiteach View Post
    Rocker arm removal.
    Agreed -- as you remove the rocker arms, take care to not allow them to slide off their shafts -- that will allow release of a gazillion tiny needle bearings (the needles are not caged -- thanks, BMW!) the rockers ride on -- 1/3 of which will, of course, roll immediately into several deep dark recesses of your workplace. The individual needles are frightfully expensive to purchase.
    Mark Neblett
    Fairfax, VA
    #32806
    Turn the crankshaft to get the pistons about half-way down the bores to avoid bending a valve, then grab the cam sprocket with a large pair of Channel Lock pliers. You'll be able to rotate the camshaft pretty easily with them. Finally, rotate the crank back to TDC, align the marks and finish the job.
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    Quote Originally Posted by mneblett View Post
    ... -- 1/3 of which will, of course, roll immediately into several deep dark recesses of your workplace. The individual needles are frightfully expensive to purchase.
    I'll bet that's where all my missing parts are...
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    Your missing socks are there, too.
    Feb 2009
    Chicago, IL
    Thanks for all the replies. I decided to with the easiest approach first. Lostboy, I took your suggestion and it worked great. Didn't even need the pliers.
