Results 1 to 15 of 16
Thread: squeel
    yappo
    squeel
    i posted this almost 2 years ago.the response was tepid.i know,i should have done more about it but hell,the front brake works great and so i ride knowing not to use the rear brake.the bike;1971 R60/5.when i got her she was a solo bike and came with the squeel.i ignored the noise and proceeded to make her into a 900cc.i then added a ural car and have been riding these last 2 years with the hack.she has the SWB.she also has a subframe for the car.i've taken off the rear wheel and looked at the brake and it's lining and components.all look ok.all fluids are up but there is an additional abnormality besides the squeel,which is, the rear wheel is not centered below the fender.it is way off to the left.the demonic squeel occurs in all 4 gears when downshifting and applying rear brake.the squeel is a real headturner at crosswalks and an invitation for comments from harley riders.
    Northern Front Range, CO
    is there a question somewhere in there, or just some observations?
    Ride Safe, Ride Lots
    Administrator 20774's Avatar
    Note: for future reference and searches, squeel is synonymous with squeal. Brake squeal.
    You say that the squeal is heard when downshifting. Are you using the rear brake when downshifting, or does the squeal happen independently of the brake?
    James.A
    Clutch throw-out? Mal-adjusted or worn out brake shoes? Something worse?
    mymindsok
    From the description, theres no way to tell.
    Quote Originally Posted by mymindsok View Post
    ..and therefore the tepid response from two years ago! Life is indeed a circle sometimes.
    yappo
    what do you think,bikerfish.
    yappo
    Quote Originally Posted by lostboy View Post
    yes, the squeal is only heard when applying the rear brake.thanks for your interest and also asking for additional info.
    yappo
    Quote Originally Posted by woodnsteel View Post
    clutch is good,as is throw out bearing.when i apply the rear brake,the action is normal and the braking action is fine.except for the very audible squeal.
    yappo
    Quote Originally Posted by RonKMiller View Post
    mucho thanks for your continued tepidity.
    Quote Originally Posted by itshimself View Post
    okay, well that now sounds like the question is "what is causing this horrendous brake noise?, and that downshifting really has nothing to do with it.
    correct?
    interweb diagnosis is much easier if you get to the heart of the matter, and toss out the extraneous noise.
    when was the last time the brake shoes were changed out?
    have you tried roughing them up with some emory paper?
    same thing for the inner drum area?
    i'd start there. these are pretty simple beasts, and there's not a lot there that is going to cause brake noise like you describe.
    yappo
    i'm painfully aware of my dismal writing ability and am sorry that this hampers further exploration of the problem.
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    Rear wheel bearing and race. Just a thought and something to check.
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    Pismo Beach, CA
    And hope that you haven't spun the race in the hub... You may want to familiarize yourself with Duane Ausherman's Wheel Bearing article; "Checking the spacing of the /5 and the /2; the "shake the wheel test".
    But I think this may be more indicative of something amiss.
    Remove the rear wheel and make sure that the Axle Reducer (15) is inserted from the left side (it will go either way), and that the Compression Ring (14) is also on the left side (or even there at all ). It is not unheard of for the Compression Ring to have ended up on the shop floor during a wheel change, and not have been replaced.
    You don't mention how "way off to the left" the wheel is, but between the Axle Reducer being inserted from the wrong side, and/or an absence of a Compression Ring, there isn't much to keep the wheel from walking back and forth across the axle.
    That will be $.02 please.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
