Results 1 to 3 of 3
Thread: Garmin 2720 cable Question
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    Not sure which direction to go in here. I need the power/audio cable for the 2720 but the cradle it sits in is the BMW NAV II. Because of something stupid that I did I destroyed the 12v connecting end. So, I go looking for this exact wire but keep coming up with the Garmin power/audio cable which does not use the left side of the NAV II (which never seemed to work anyway ). Ok, collective wisdom, any suggestions on how I might proceed? (yes I know that I could contact Garmin but they only show the non BMW cable) Any value in retaining the original NAV II connection? Any way that I can make what I have work again? Here are a couple of pictures of what I have:
    Thanks, Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    Aug 2005
    recommendations? - Bob
    Bob Weber
    What kind of bike is this for? It looks like there are different cables for "plug-in" install for different bikes - do a search on one of the online parts fiches for your bike under "Accessories." They are all available, just expensive.
    Which end of the cable - the one that attaches to the GPS or the end to the bike? In looking at the pics it looks like you cut off the bike-side plug connector(s) and are left with three wires, red/black and purple. In looking online it looks like the standard connector has the GPS on one end and the other end terminating in two blocks, a 2-prong (red and black wires) power and another 2-prong (purple) which looks like it is for speed (to feed the GPS data when out of sat range.) From posts on ADV Rider it looks like you can cut the blocks (which it looks like you've already done ) and simply wire in the red/black for power either hard or through a powerlet (fuse optional but probably a good idea) and just seal off the purple and forget it.
    I found this with a quick Google search, the "applications" part towards the bottom might be a good starting point.
    Ted
    1994 K75RT
    Moto Pages
