Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 73
Thread: Dyna beads R1200GS
  1. #16
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    something about weight moving to the light spot on a rotating mass just doesn't seem to work for me. I believe MCN also had a bit of a problem with that theory.
    As well they should... that's not the theory behind how the beads work.
    The beads do nothing to balance wheels/tires. What they may do is balance the effect that an out of balance wheel/tire has on your suspension. It is the up/down of your suspension that may be balanced, not the rotating wheels. Without a moving suspension the beads do nothing.
    Note: I don't use them and likely never will for various reasons. I just wish that someone who understood what they were supposed to do would rig up a reasonable test. Putting a wheel with beads on a spin balancer that measures axle strain does only shows that the people running the test (yes, I'm talking about MCN) are clueless about how the beads could work. It doesn't help that the beads are marketed as something that will balance your wheels/tires. They can do no such thing.
  2. #17
    Jul 2008
    Omaha
    I'm always a bit slow (hey I have a Polish ancestry and grew up in a small town in Nebraska - that's like two strikes right out of the gate, right). Here's where I'm confused. If beads balance out the up/down effect that an out of balance wheel/tire has on the suspension, and the axle of the wheel/tire is rigidly attached directly to the bottom part of the suspension, wouldn't that mean the beads were distributing themselves inside the tire in a way that also stopped the unbalanced wheel from going up and down (due to the inbalance)?
    Other than that the wheel needs to be rotating for it to happen (I suppose that's why they use DYNA in dynabeads), how is that any different than using weights on the rim to stop the up and down movement of the wheel/tire due to an inbalance?
  3. #18
    Spring Lake NJ, USA
    The moving suspension part is fine - but a heavy spot will try to move outward harder then a light spot - so when the heavy spot crosses the movement axis of the suspension - the wheel will tend to move up (if the heavy spot is UP) or down (if the heavy spot is down.)
    That's a given. What isn't a given is exactly HOW and WHY the Dynabeads would tend to go to the opposite side from the movement to counteract the movement.
    So - what is the theory behind how the beads work?
    Actually IMHO - that's a good test. The "spin balancer" actually measures displacement forces on the center axle going through the mounted wheel. It does this when the wheel is MOVING - not when it's stationary.
    Problem with many motorcycle ones (like the Snap-On one I usually use) - is the rotational speed may not be enough to trigger the magical effects of Dynabeads..
    But - automotive spin balancers are usually electrically driven - and will spin a tire up to 50-60 MPH to measure imbalance. It would seem that if the effect is real - Dynabeads could be shown to work on a car tire mounted in a high-speed dynamic spin balancer.
    So far - I've never seen that happen. Has it? Inquiring minds want to know..
  4. #19
    Jul 2008
    Omaha
    I don't get why that would be such a mystery. The beads act like a low mass fluid inside the tire. Been a while on my physics, but when the heavy spot tries to move outward like you described, isn't it accelerating away from the beads directly below the heavy spot on the inside surface of the tire? The beads are fluid and they flow/roll back towards the light spot on the tire as the heavy spot accelerates away.
  5. #20
    Mar 2008
    Camas Valley Oregon
    Snake Oil! It only works if you "believe" in it.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
  6. #21
    Jun 2008
    SF Bay Area
    Beads need suspension movement, not the forces that would generate that movement, to have a chance at working. The beads DO NOT BALANCE THE WHEEL. They may balance the effects that an out of balance wheel have on a moving suspension by changing the the coupled mass of the wheel.
    An out of balance wheel will tend to compress the suspension as the heavy point is in line with the spring. When it does this the tire, for a brief bit, moves away from the beads that are at the top of the arc. For that brief bit the beads at the bottom are coupled to the wheel but the beads at the top are not. The mass changes. That's the theory as I understand it. I think I see how it can work. But....
    • how fast does the wheel need to spin?
    • how much suspension movement is needed?
    • what effect has suspension movement not associated with an out of balance wheel?
    • how well/fast to the beads react to varying wheel speeds?
    • what, if anything, do beads do to the inside of your tire?
    • since the wheel is not balanced, is there extra wear on wheel bearings?
    Those are a few of the unanswered questions that keep me from using beads.
  7. #22
    Dale Rudolph
    May 2009
    Medford, Oregon
    Let's say that dynabeads do work. Don't they all settle on the bottom of the tire
    each time the bike comes to a stop? Seems like you would have a very out of
    ballance tire each time you start off until you reach a speed where they would start to work.
  8. #23
    Jul 2008
    Omaha
    Quote Originally Posted by DRUDOLPH148006 View Post
    Very true. IIRC, the dynabead guys say the beads are working completely somewhere around 25 MPH. Low enough you don't notice the imbalance.
  9. #24
    Jul 2008
    Omaha
    FWIW, "How it Works" from the dynabead site...
    http://www.innovativebalancing.com/HowItWorks.htm
  10. #25
    Braintree, MA
    Quote Originally Posted by alzyck View Post
    I'm open to seeing some proof. Testimonials and graphics are not proof.
    -Tom (KA1TOX)
  11. #26
    Jul 2008
    Omaha
    Quote Originally Posted by tommcgee View Post
    So, who said the testimonials and graphics were proof of anything?
    There's been an ongoing discussion of how dynabeads work with different opinions on if and how they work. The link provided an explanation from the perspective of the company that makes them. Nothing more or less.
    I'll go have my beer now.
  12. #27
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    The current administration in Washington. Ask them.
    Doug, 2011 R1200RT Polar Metallic
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
  13. #28
    1aretea
    It seems like the people who tried Dyna Beads, like them. The others want to disprove them.
  14. #29
    Braintree, MA
    Quote Originally Posted by 1aretea View Post
    I'm one who tried them and took them out 3 days and 300 miles later.
    -Tom (KA1TOX)
  15. #30
    From MARS
    Why?
    I've been using them for over a year, in three sets of tires (both tubed and tubeless) on my GSPD, with very good results.
    Tom
