Just Installed! Clearwater "Krista"
paulsgs
I have been waiting for my pair to get here and finally got them on last weekend. Some early thoughts, you get what you pay for. The wiring harness, and all other connectors are of the highest quality I have ever seen. (I've installed a Stebel Horn and front and rear Photron Led's) so the difference is striking. The lamps themselves are extremely rugged as it the dimmer . Here are some pix during the daytime, I plan on doing ther nightime test over the weekend.
These are on the normal low beam
How difficult were they to install? Are the wiring harnesses "plug and play" or did you have to cut and splice? They look super bright! I've found that with LEDs, their performance gets better as the environment gets darker. The Krista's almost make the Photron LEDs look laughable in comparison.
They were basically plug and play. The directions were a bit vague when it came to wiring to the hi beam switch, but after figuring it out, I told the guys at Clearwater and they will/did adjust the directions. There is one posi tap you have to do, then you take out the parking bulb and slip in the included harness and it all works! The wiring is really heavy duty. I hope to have some night time pix soon (so you know, I did take some head on ones, but it was sooo bright, the pictures were a total white out)
Yeah but whats the riding experience like?
Do they open up the dark sufficiently to justify the cost? Do they bother on coming drivers?
Lo Beam no aux lights
This was lo beam with the Krista's covered up
Hi beam w/o Clearwater
Hi beam with Clearwaters covered up
Hi beam with Clearwaters on full
Clearwaters on full
Cockpit view, lo beam
Lo beam on, Clearwater on low
Hi beam, with Clearwaters on full
Cockpit view, all on high
Thank you very much for your post. I am very interested in the Krista's and this helped me a lot. How much disassembly of the bike was necessary for the install?
Ray
Nice write up!
I've had Kristas on my sidecar rig for about three weeks now, and recently got to try them at night in rural PA. With my wonderful dog in the sidecar I live in dread of encounters with deer, but these lights were so fantastic at not only throwing light downrange, but at illuminating the sides of the road that I was able to spot the hooved devils WAY before they became a concern!
