Results 1 to 9 of 9
Thread: Marks from rotor bolts
    tourist
    Just replaced my tires on my '10 k1300gt and saw this mark, one on each side. It appears to the same level as the bolts that hold the rotor plate onto the wheel.
    Is this normal? I see nothing loose and there is clearance between the area on both sides. I can imagine it making marks if there is some kind of flexing going on.
    Jun 2007
    Don't know if its normal, just now have my K1300S wheels of and did not notice anything similar, but did not look, will do so when I remount tomorrow. Is there any corresponding mark on the rotor carrier bolts? It looks oversized for a mark from the carrier bolt. From the pic, I can't tell if there are any striations in a curved pattern which would I would expect if caused by the carrier bolts.
    Jim Douglas '00 K1200RS >137,000 miles -- owned since new,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    tourist
    I don't see any marks on any of the bolts and I don't real see any striations from the bolt unless they are really fine. The mark on the other side is about half that size. The top portion of the marks are deeper than the bottom portion. It really doesn't look like it would be caused by the bolts but that is the location.
    Sep 2006
    sent you a PM...
    Steve Henson
    dmmwam
    I have those same marks on my forks. Another interesting thing I was noticing is that there is a larger space between the fork and the wheel on one side than there is on the other. One would think that the wheel would be centered between the forks. I just had new tires installed at the dealer a few weeks ago. You would think anything abnormal would have been brought to my attention.
    dmmwam
    Throttle side spacing.
    dmmwam
    Clutch side spacing.
    tourist
    dmmwam, I noticed the same thing about the spacing but the center of the tire looked centered so I stopped thinking about it.
    Jun 2007
    Finally got to slap my wheels back on without any rain.....I did check and my rider's left fork leg on the 1300S also has such a spot. Exact same level as the carrier bolts, but no way they could ever reach it. No curved striations from contact. It appears that it was a factory grind, smaller than yours and only on the one side. My wheels also appear slightly offset at the hub, but the rim appears centered. Certainly tracks fine. I have no worries on that.
