Results 1 to 4 of 4
Thread: Givi topcase mounted to K1300S
    Chairman of the hoard wmubrown's Avatar
    Nov 2004
    Kalamazoo, MI
    Since buying my K1300S last fall I've been trying to figure out a way to get a 'real' topcase on the bike... a Givi to be exact. I've been using Givi products since a 22L topcase fell off my K100RT many years ago, and before Givi even had a US importer. I have clearly been incredibly happy with their product.
    I faced a dilemma: how do I get a Givi topcase on my K13, and should I wait to see if Givi comes up with a kit? I waited through winter, but now riding time has arrived and I have trips to take. I ordered the Givi K1200S kit thinking it ought to line right up. I was wrong. The top tail piece of the K1300S flares out to match the lines of the body, while the K1200S has a narrow tail section. I screwed up some courage, checked with the dealer that I could order a new top tail piece (I can, its $70) and then started to work modifying the tail piece to accommodate the support brackets that bolt into the rear subframe of the bike and the back of the Givi mount plate, which in turn bolts to the BMW side case arms and luggage plate.
    Here are some prelim photos of the final result. I'll get some outdoors in daylight tomorrow (assuming it doesn't rain all day as predicted). I hoping to get out and ride tomorrow also and see how it handles:
    John A. Brown - Kalamazoo MI
    '09 K1300S 'Zoot' (Wicked, bad, naughty, evil, Zoot!)
    '94 K1100LT 'Desert' (the horse with no name)
    Mar 2007
    Minneapolis, MN
    John,
    Looks great! Where did you get the kit for topcase only that fits with the OEM sidecases? I'd like to have that same setup.
    Cromwell2
    '16 R1200RS
    '04 Rockster
    Nov 2004
    Kalamazoo, MI
    Quote Originally Posted by pennyha View Post
    John,
    Hey Penny... Thanks! I used the Givi topcase mount for a K1200S. I had to modify the K1300S tail section (ie-cut holes in it on both sides) for the bracket to bolt into the frame where the sidebags mount. Then the front portion of the Givi plate bolts into the BMW topcase bracket, and the rear bolts into those support brackets. I should get a close up shot of the tailpiece...
    Jun 2007
    More Pics please
    Yes, good shots of the way you got the 12S brackets to bolt up to the 13S, without the top case or your stock bags on would be great. How it bolts to the stock rack, etc would be beneficial as well. I am seriously thinking of doing this.
    Looks great so far!
    Jim Douglas '00 K1200RS >136,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
