Results 1 to 7 of 7
Thread: Zumo 660 mount on KGT
    Registered User Overkill's Avatar
    May 2007
    New Hampshire
    When my last GPS died I had trouble finding the right mounting combination for my new zumo 660. I settled on a bracket I made attached to a gadget guy mount attached to a touratech mount. This put it in the right position for me and gave me the ability to keep it locked along with vibration protection. With this set up I am also able to adjust the angle of the screen. I hope my idea may help someone else with the same problem
    http://i305.photobucket.com/albums/n...inal/zumo3.jpg
    Friends are people who know you, but like you anyway!
    Aug 2008
    Kingston, NH
    Looks great - can you provide a shot or two of the mount only.
    Maybe one from the front and side.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    May 2007
    New Hampshire
    Here you go!
    I am not very impressed with the touratech mount. The locking mechanism is cheezy and not nearly as good as the old one on my 2610. I guess it looks like it is strong which would help deter someone, but I think you could rip it open pretty easy!
    Aug 2008
    Kingston, NH
    Thanks for the additonal pictures.
    Question on the Gadget Guy mount - I have one too, but mine connects across the handle bars, where as youes appears to come up from the bottom and then it is attached, was this another modification or did you have Genna make the mod for you/
    2009 G450X White
    IBA #35651
    Rogue Moderator
    GPS Mount
    That is one very nice mount. Great job.
    Don S
    May 2007
    New Hampshire
    I believe it is two of his mounts. I don't rember the part numbers because I have had it for a couple years. It used to hold my Garmin 2610 and then I just changed it around for the 660. I also have the mount that goes between the handle bars but I liked this better. In order to use this I had to build a bracket to mount it to though. I am pretty sure you can get almost the exact same result with the Ztechnic mount and a lot less work and $, but I already had this so.... I
    May 2007
    New Hampshire
    Thank you Packy!
