Results 1 to 8 of 8
Thread: Fehling Euro Bars - 22mm or no?
    poorboywilliams
    Hi All-
    I recently picked up a set of Fehling euro bars from Hucky's along with a complete set of cables as the final step in getting the old '74 R90/6 back on the road. I assumed these bars were 22mm and not 7/8" since a) Hans was selling them, and b) they're made in Germany. But when I try to slide the control mounts back on, the bars seem a little too big. To compare, I tried sliding them back on the original Magura USA high bars... no problem, slid right on.
    So there's essentially a pinch fitting that holds the controls in place on the bars. Is there a safe way to open this up? I was gently prying with a large screwdriver last night but I really don't know how brittle that metal is. Any suggestions? Maybe a little heat?
    I think you need to get your money back. Hucky should know better and/or put something on his website.
    poorboywilliams
    Bummer! Hucky's site gives metric measurements for length and rise, so I figured they would have to be 22mm diameter. But.. those controls just don't want to slide on.
    Pismo Beach, CA
    Put a set of mics, or calipers on them:
    22mm = .866"
    7/8" = .875"
    Fehling's website lists their "22mm" products with a (7/8") notation; not a good sign.
    They're into Harley stuff now... . 25.4mm [1.0"], 30mm [1.187"].
    Good luck with Hucky...
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Jun 2007
    Portsmouth, NH
    I bought some 22mm bars made by Flanders. My controls would not fit over the ends. When I measured the bars, they were indeed 22mm, but the bars had a slight flare on the ends. A quick hit on the belt sander and the controls fit right on. I'd guess the flare was caused by the cut off tool.
    poorboywilliams
    Anyname gets the gold star, and I get the dunce cap for not checking this sooner. I got out the calipers last night and confirmed that about 99% of the bar is in fact 22mm. The portion that isn't is the last 0.25" or so on either end, flared presumably at the factory as a result of cutting the bars. Thanks all!
    Registered User melville's Avatar
    May 2010
    Behind the Redwood Curtain
    Quote Originally Posted by poorboywilliams View Post
    Good! Same here, recent purchase of Fehling euro bars from Hucky. I measured and got the same result, but had not checked the fit of the controls yet.
    Jun 2007
    Portsmouth, NH
    Mom will be so proud that I finally amounted to something....
