Results 1 to 6 of 6
Thread: Throttlemeister
    Aug 2005
    Chapel Hill NC
    Throttlemeister
    Does anyone out their know how to adj the throttlemeister. I have one on my 2004 R1150RT it has work well for years. Lately it will not hold unless I turn on my heated grips. So I need some help.
    Bill
    Had the same problem about 7 years ago, also on an R1150RT. You adjust the position of the brake housing on the handlebar, not the TM. What likely happened is that you had the TM on, then turned on the heated grips. As the grips got hot and expanded the force pushed the brake housing toward the center of the handlebar.
    At least that's what happened to me. Once fixed I stopped it from happening again by making sure I never locked the TM until after the grips came up to temperature.
    Registered User ESSNOWYT's Avatar
    Jun 2007
    Somewhere Strange Wisconsin
    How does one go about adjusting the position of the brake housing?
    Thanks.
    Snowy.
    BUDDINGGEEZER
    The throttle side of the Throttlemeister comes with small washers ,used as shims to set it closer or farther away from the bar end or grips. You have probably worn away the end of the grip. Remove a washer and the TM will contact the grip harder. Works with your heated grips since the grip expands when hotter.
    Ralph Sims
    Quote Originally Posted by Essnowyt View Post
    Name:  Screen shot 2010-05-16 at 3.45.00 PM.png
    Eight year old memory says: remove two screws (6), loosen 8, adjust.
    I don't know that I'd trust my eight year old memories, that much.
    Registered User Dubuque's Avatar
    Sep 2004
    Banos del Inca, Cajamarca, Peru
    Bill,
    Attached is a pdf file that I got from Throttlemeister on how to adjust the unit. I have an 2004 1150RT also and I have to adjust mine about once a year or two. Simple to do, just takes a about 15-20 minutes.
    Tom
    Tom
    Here we are!
    2004 R1150RT
