Results 1 to 15 of 22
Thread: 8.49 second 158 MPH pass
    Lifetime Member Ridealot's Avatar
    Aug 2004
    Salem Or.
    So is the motor in the new S1000RR fast. Why yes, yes it is!
    http://www.youtube.com/watch?v=OxcBK0IuC0o
    Here are the mods.
    2010 BMW S 1000 RR
    Engine: Stock (203 RWHP/80 ft-lbs SAE Scale using VP MRX01 Fuel)
    Exhaust System: Brock’s Performance Full Titanium CT-FM™ Carbon Tip Megaphone... with Anodized Flames
    Fuel Injection Control: Dynojet PCV with Brock’s Performance Custom Map to match the CT-FM.
    Wheels: BST Carbon Fiber
    Tires: Michelin 120/60 Power Pure Front - 190/50 Power One Rear
    Bearings: Worldwide Bearings Ceramic
    Swingarm: Brock’s Performance 9” over Alumi-Pro™ by McIntosh
    Shock: Brock’s Performance Dragshock™ by ?ûhlins (Dual Stage Compression with Remote)
    Sp Vortex (17-47 to start)
    Chain: Regina 530 ZRP 160 Link (O-Rings removed by hand)
    Clutch Modifications: Brock’s Performance Clutch Mod, Cushion, Springs with Adjustable Spring Tops and Shims
    Lowering Links: Brock’s Performance Window Links
    Front End: Brock’s Performance Radial Mount Front End Lowering Kit (Radial Mounts, Strap End Kit, Strap)
    Oil: Alisyn <<0 Weight
    Oil Additive: Petron Plus
    Coolant: MoCool by Motul
    Mirror Block Offs: Brock’s Performance
    Brake Line-Rear 9” over: Spiegler Performance
    Brake Pads: Carbone Lorraine (SBK5 Compound)
    Seat: Custom Cover by Bob Kussman Dayton, OH
    Special Thanks: Scott Robertson
    Tom
    Salem Or.
    '93 K1100LT w/Bushtec
    '03 F650CS '09 F650GS
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Damn!
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    >optimize my '84 Ninja like they did this bike and it wont be far behind it. <
    I think BMW is starting to get the attention of lots of younger folks! LOL
    460
    -Albert Eienstein
    Registered User texanrt's Avatar
    Nov 2008
    Houston
    Quote Originally Posted by 460Jetboat View Post
    460
    Yes it is --- I was talking to a couple of young guys about 1-liter bikes when they mentioned how cool the new BMW was -- both thought it was a $20,000 + bike because it was a BMW -- when I told them the list price their eyes lit up -- they couldn't believe it.
    Texan RT | Houston | IBA
    BMW R1200RT | HD Road Glide
    Nov 2008
    Houston
    S1000RR vs Corvette
    Oct 2008
    Laurel, MD
    A stock S1000RR has 203 hp at the wheels?
    1994 K75/2
    Owner/Designer, LampOneDesigns.com
    Nov 2009
    Atwater, CA
    It had a pipe & some computer tuning... Otherwise, stock inside...
    Oct 2008
    Laurel, MD
    Quote Originally Posted by JStrube View Post
    Wow, thats awesome that you can get that kind of power out of it
    1994 K75/2
    Nov 2009
    Atwater, CA
    I wonder how long until someone takes one to Bonneville.
    Sep 2009
    SW, MO
    I would guess there will be one there this summer!
    -Albert Eienstein
    Aug 2008
    Kingston, NH
    Outstanding!
    Quick question - why did you remove the o-rings from the chain?
    Quote Originally Posted by Ridealot View Post
    Here are the mods.
    2010 BMW S 1000 RR
    Exhaust System: BrockÔÇÖs Performance Full Titanium CT-FMÔäó Carbon Tip Megaphone... with Anodized Flames
    Fuel Injection Control: Dynojet PCV with BrockÔÇÖs Performance Custom Map to match the CT-FM.
    Swingarm: BrockÔÇÖs Performance 9ÔÇØ over Alumi-ProÔäó by McIntosh
    Shock: BrockÔÇÖs Performance DragshockÔäó by ?ûhlins (Dual Stage Compression with Remote)
    Clutch Modifications: BrockÔÇÖs Performance Clutch Mod, Cushion, Springs with Adjustable Spring Tops and Shims
    Lowering Links: BrockÔÇÖs Performance Window Links
    Front End: BrockÔÇÖs Performance Radial Mount Front End Lowering Kit (Radial Mounts, Strap End Kit, Strap)
    Mirror Block Offs: BrockÔÇÖs Performance
    Brake Line-Rear 9ÔÇØ over: Spiegler Performance
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2004
    Salem Or.
    My guess would be for less rolling resistance. With O ring chained bikes if you try and spin the back tire by hand your lucky if the tire makes much more than a complete rotation before stopping. In the old days before O rings the tire would make a few turns before stopping.
    Tom
    Salem Or.
    Aug 2008
    North Carolina Coast
    Chain Lube . . . .
    On the S1000RR how is the chain lubed?
    Aug 2004
    Salem Or.
    Quote Originally Posted by CTellman View Post
    Same way you lube any chain.
    Tom
    Salem Or.
    Aug 2008
    Kingston, NH
    OK - so you sacrifise some chain life for less resistance - makes sense
    2009 G450X White
    IBA #35651
    Rogue Moderator
