Results 1 to 15 of 19
Thread: Caster ?
    bobh41
    Caster ?
    Definition please (it's not in my engineering manual).
    Comparing the R1200GS , R1200RT, and R1200S - the BMW specs lists "castor" for each as 101, 116, and 87 mm, respectively.
    I think this relates to "trail", but I'm not sure. If that's so wouldn't that make the "S" a little spooky?
    Help?
    Bob
    Caster is the difference between a vertical line and the steering axis. Bikes have positive caster in that the steering axis is angled forward from vertical. If measured as an angle it is called rake. I have no idea where BMW is measuring from to express it in millimeters but less caster is less rake.
    And yes, the S has more "upright" steering and turns in more quickly. Not surprising for a sport bike.
    Jun 2005
    Green Bay, WI
    Those must be values for trail, in milimeters. Caster, is essentially the same as trail. Plus those numbers make sense for trail for each respective chassis. I wonder if my 94 R1100RS is between the S and RT.
    bobh41
    RS Caster
    The Clymer manual cites 111 mm Caster for the R1100 RS.
    R=127 mm
    GS=115 mm
    RS=111 mm
    RT=122 mm
    S= 100 mm
    It does not distinguish model year.
    Quote Originally Posted by bobh41 View Post
    "Castor" is French for beaver.
    Mike Marr
    Jul 2008
    Central PA
    Quote Originally Posted by MotorradMike View Post
    Less beaver will make me quicker?
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    Sep 2006
    Quote Originally Posted by 36654 View Post
    That's what my HS Track coach told us
    Steve Henson
    bobh41
    Track
    Funny, my HS coach never mentioned that. I ran the mile in 11 minutes.
    Jul 2008
    Central PA
    Any regrets?
    Dec 2007
    Reno, NV
    Castor is something you take when you eat too much cheese.
    bobh41
    "Any regrets?"
    Yeh... that 26-inch inseam (then).
    castor is what you burn in 2-stroke racing engines.
    No longer a member here
    Apr 2006
    There is no way I would attempt to challenge your authority, Paul, when it comes to technical issues on motorcycles, but I must point out one small issue:
    While rake and trail (caster) are related, they are not the same. Rake is the angle of the steering neck from vertical. Trail is produced by the offset of the fork tubes relative to the steering neck. If you increase the rake you can decrease the trail by reducing the offset. This is done often by custom bike builders of a certain brand of motorcycles. Any bike in order to have halfway decent steering needs a positive trail. If you don't have one, you would have the "broken wheel on a shopping cart" syndrome. Below is a picture to illustrate the relation. A large trail makes steering heavy and "slow" but increases high speed and straight line stability. A small trail makes steering quick and easy but produces a very "tippy" reaction and can be dangerous at low speeds and tight turns.
    Quote Originally Posted by ima4nr View Post
    We are not disagreeing. And it was BMW that described an angular measurement (caster) as a dimension in mm, apparently trail. And subsequent posters who said BMW meant trail.
    What I said was "Caster is the difference between a vertical line and the steering axis." Which is what you just said rake was. And I said caster and rake were the same thing. We agree. They are an angular measurement. Trail is a distance measurement.
    Apr 2006
    We are not disagreeing. .
    We are indeed not, Paul. After reading it again, I saw that you explained caster as rake, not trail. Makes sense, as caster in a car suspension is expressed in an angle measurement.
