Results 1 to 8 of 8
Thread: Sound of a leaking head gasket
    I have an odd noise coming from the right side of the engine, a sort of rapid squeaking sound. Clymer's indicates this is a leaking head gasket. Short of a leak down test (I don't have the tools) is there any other way to diagnose this?
    61 Gold Star, '13 690 Duke, '13 Daytona 675R, '14 Street Triple R (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
    Dec 2007
    Reno, NV
    Why not just take something that smokes, like a stick of incense or a cigarette, and with engine running observe the smoke as you pass it slowly and closely around the head gasket perimeter? Just need a space where the air is calm.
    Administrator 20774's Avatar
    Also, you can take a paper tube like from some gift wrap and direct it to specific areas around the head to help pinpoint the location of the noise.
    TGHSMITH
    if you have the silicon valve cover gaskets, and they are not tight enough they can act like the reed in the woodwin section of the symhony.. check the area first, plus the old style breather valve can be fairly musical also..
    Registered User f14rio's Avatar
    mattituck new york
    apply soapy dish water and watch for bubbles?
    might work if it isn't too hot. i dunno.
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
    scqtt
    Turkey Gobble?
    My R90/6 did this, I thought it was something with the crankcase breather check valve.
    Northern Front Range, CO
    Quote Originally Posted by SCQTT View Post
    Turkey Gobble?
    breather valve was my first thought as well. my leaking head gasket leaked oil as well as air.
    Ride Safe, Ride Lots
    Thanks all. I found the sound was coming from elsewhere. One of these days I'll get the hang of this home mechanic thing.
