Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Need to add a fuse panel...recommendations?
  1. #16
    He Who Rests Rots! pfiedler's Avatar
    Apr 2009
    Boxford, MA
    Doug,
    Derek from Touratech confirmed that as well and I ordered the silver locking mounting kit for my bike. Thanks!
    I checked the BMW microfiche for a part number for that black plastic piece centered on the handlebars that the Zumo base attaches to and couldn't find anything. I just sent an email to Rose Marston at Max BMW in North Hampton, NH where that piece was installed in March of 2009 when I picked the bike up. I'm sure she'll get back to me with the info and I'll pass that along right away.
    Have a great day and ride safely!
    Best,
    Peter
    Peter Fiedler
    BMWOA #148776
    2012 K1600GT Grey/Silver
    2013 R1200GSW Thunder Grey
  2. #17
    Apr 2009
    Boxford, MA
    Doug,
    BMW part number is: 71607676868
    Call Rose Marston at Max BMW and she'll get it out to you right away. Her contact info is:
    Rose Marston
    Apparel Specialist, Accessories and Parts
    MAX BMW Motorcycles
    209 Lafayette Road
    North Hampton, NH 03862
    phone: 603.964.2877 x123
    fax: 603.964.2879
    Open Tuesday-Friday 9-6, Saturday 9-4
    Good luck and please ride safely!
    Peter
    Peter Fiedler
    BMWOA #148776
  3. #18
    Apr 2007
    Tampa, FL
    Super! I'll give her a call tomorrow. Thanks, Peter!
    Ride Safe!
  4. #19
    Dee G flymymbz's Avatar
    Nov 2006
    Central WA
    Quote Originally Posted by dwestly View Post
    Ok, now that I've got my Zumo 665, Adaptiv radar detector and Coo Case mounted on my K13GT, my battery terminals look like spagetti central. I've got to get a fuse panel mounted. Obviously the GPS and detector will go on the switched terminals of the panel, and the case will go on an unswitched terminal. Recommendations for the fuse panel (I'm thinking a Centech), where to mount it, and where the heck is the best place to tap the switched lead, given the CanBus?
    Only recommendation I can give is for the fuse panel. I have three Fuzeblock units mounted on three different bikes. Six available slots and you can chose how many are switched or unswitched. Its a bit taller than the Centec, but the relay is built into it. Just picked up a new to me R850R, and am going to be ordering another one for it. And I usually stick the GPS on 'unswitched'. That way I can have it hooked up to the bike and program it without having to switch on the key.
    http://www.fuzeblocks.com/
    Too damn many bikes to list
  5. #20
    Apr 2009
    Boxford, MA
    Ride Safe!
    Doug,
    Did you ever end up getting the GPS bracket from Max's for your bike? If so, how did the install go? I just received my 665 yesterday and I'm about to start the removal and install of the new GPS. Where did you grab your power from for the new unit? I may just run a line back to my Centech and go that route. Too bad Garmin ended up with a whole new wiring harness for the 665. More work = more aggravation!
    Ride safely!
    Peter
    Peter Fiedler
    BMWOA #148776
  6. #21
    Apr 2007
    Tampa, FL
    Not yet. After that discussion, I ran into a mechanical issue with the GT. See my thread on my alternator failure. I get the bike back later today (finally), so I can get back to the GPS stuff now...
  7. #22
    Apr 2007
    I bought a Centech
    Mounted it under the seat
    Hard-wired to the battery
    Used the accessory socket lead to trigger the relay
    Used it to install:
    A hard-wired, always-on accessory socket next to the stock one
    A second hard-wired, always-on accessory plug (tucks under the seat)
    Power for a Nuvi 550
    Zero issues
  8. #23
    Apr 2007
    Tampa, FL
    How did you run the cables from the seat area up to the battery? That seems like a real pain getting them up there... I just received my CenTech panel and cables, but haven't mounted it yet, as I'm still figuring out the best spot for it.
  9. #24
    Aug 2008
    Kingston, NH
    To me it is real easy for the centech to be up front over the battery.
    If you got the relay trigger you can mount that onto the ABS shelf
    http://forums.bmwmoa.org/showthread.php?t=43031
    And the trigger is off of the courtesy light - instant off and on.
    2009 G450X White
    IBA #35651
    Rogue Moderator
