Results 1 to 15 of 24
Thread: Need to add a fuse panel...recommendations?
    Apr 2007
    Tampa, FL
    Ok, now that I've got my Zumo 665, Adaptiv radar detector and Coo Case mounted on my K13GT, my battery terminals look like spagetti central. I've got to get a fuse panel mounted. Obviously the GPS and detector will go on the switched terminals of the panel, and the case will go on an unswitched terminal. Recommendations for the fuse panel (I'm thinking a Centech), where to mount it, and where the heck is the best place to tap the switched lead, given the CanBus?
    Registered User stkmkt1's Avatar
    Sep 2008
    Tremont, IL
    I did a Centec AP2, but wired both hot wires to the battery rather than one. That gave me up to eight circuits. Mounted it under the seat and it works great.
    '09 BMW 1200 GSA, 2013 BMW 700GS, 2000 Goldwing SE, '09' V Star 950, '09 Honda Rebel,
    '77 Honda 750A. Holding at six til I get new garage built - need more room for more bikes!
    He Who Rests Rots! pfiedler's Avatar
    Apr 2009
    Boxford, MA
    Quote Originally Posted by dwestly View Post
    Ok, now that I've got my Zumo 665...
    Ooh...just ordered one of the 665s from GPS City and should see it in about 2 weeks they say. How did you mount it on the K13GT? I have a K12GT (2008) which currently has a Zumo 550 mounted mid bars. Is there a BMW mount for the new 665? I imagine I could reuse the current wiring harness for the 550 with the 665 so long as I don't need to come up with some new mounting process.
    Thanks for any advice.
    By the way, I use the Centech AP-1 and mounted it right over the rear wheel under the back seat. I believe you can grab the parking light lead for your switched access. The dealer did the install for me when I bought the bike about a year ago. I'm sure you will get lots of feedback via the forum including pictures. You might also check the DIY section to see if there's an install process listed there.
    Please ride safely.
    Peter
    Peter Fiedler
    BMWOA #148776
    2012 K1600GT Grey/Silver
    2013 R1200GSW Thunder Grey
    Aug 2008
    Kingston, NH
    Quote Originally Posted by pfiedler View Post
    Peter
    As requested
    http://forums.bmwmoa.org/showthread.php?t=43031
    The trigger I used (parking light) is instant on and off.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Apr 2007
    Tampa, FL
    Thanks for the DIY link. As for the 665, it comes with standard RAM mounting attachments, so you can use an existing RAM setup, if you have one. I ordered the Touratech locking Zumo 660/665 mount for added security, as the standard 665 mount just doesn't look that sturdy to me. I had the 550 on a RAM mount on the left handlebar of my K13GT, so I just swapped the 665/Touratech onto the existing RAM mount.
    Apr 2009
    Boxford, MA
    Dwestly,
    Thanks for the info. Would you happen to have a picture of your set-up you could post to the forum? I'm sure others would appreciate it as would I!
    Please ride safely!
    Peter
    Peter Fiedler
    BMWOA #148776
    Apr 2007
    Tampa, FL
    Here you go. The RAM mount is the standard U-bolt configuration with the short arm on it. The 665 now has a single cable running from the mount, containing the power, XM antennae, audio out and mic wires, which split further down the cable. This makes for a nice, clean mounting and reduces the chances of a faulty connector at the mount. I have the XM antennae mounted low, between the handlebars. This was also a leftover mount from my 550 XM antennae, so I just re-used it. BTW, the new 665 takes a micro SD card, not the standard size SD card used in the 550.
    If you've got any questions, drop me a line
    Aug 2008
    Kingston, NH
    Very nice set up. If you are interested you can mount the GXM antenna up under the front plastic with no adverse effects to reception. Let me know and I can post the pictures.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Apr 2007
    Tampa, FL
    Thanks. I thought about it, but this works ok for me. The antennae is out of the way and just sits there, being happy...
    Aug 2008
    Kingston, NH
    Not a problem - figured i'd offer
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Apr 2007
    Tampa, FL
    I just ordered the Centech AP-2 and harness. Would it be possible to tie the switched line into the power outlet line, on the left side of the bike? Would seem to be an easier place/wire to reach than having to disassemble the entire front of the fairing...
    Apr 2009
    Boxford, MA
    Thanks for posting the pictures...very nice set-up!
    Looks like the 665 with the Touratech locking bracket uses the standard 4-hole ram mounting arrangement like the 550's mount did. After looking at my bike last night, I think I might be able to use the existing plastic BMW GPS mounting bracket (centered on the bars with the 4-hole ram arrangement) to mount the Touratech bracket and the new GPS. After looking at a PDF of the owner's manual for the 665, I'm now certain that I'll have to run a new cable to power the 665 and allow for connection of the GXM-40 puck etc. Thanks as well for the info on the SD card. Nothing a quick drag and drop on the Macintosh from one card to the other won't fix! By the way, any noticeable increase in music loading times? I currently run about 4GB of data on my card which, on the 550, slowed down the boot up time to some degree but not terribly.
    Anyway, this is most helpful and thank you again. I will let the forum know how things progress with my install of the 665 and post some pictures once I finish not screwing up the install!
    Take care and please ride safely!
    Peter
    Peter Fiedler
    BMWOA #148776
    Apr 2009
    Boxford, MA
    Here's my current set-up for the Z550. Note the black plastic mounting piece (BMW part) upon which the 550 mounts. I hope I can use this same back plate for the 665 with the Touratech bracket. What do you think?
    By the way dwesterly...great Adaptiv radar detector users think alike huh?
    Please ride safely!
    Peter
    Peter Fiedler
    BMWOA #148776
    Aug 2008
    Kingston, NH
    Yes you can do that - the reason I set mine up like that is that the parking lights do not have a delay as other voltage signals.
    Luis
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Apr 2007
    Tampa, FL
    Cool, thanks Luis.
    Peter, you should be able to use the same mounting plate for the 665, as the mounting holes are identical between the mounts. BTW, what's the part number for that KGT bracket? I wouldn't mind relocating my 665/Touratech mount...
    Doug
