Results 1 to 13 of 13
Thread: Twinmax repair
    Scottish Transplant Picinisco's Avatar
    Mar 2007
    The Desert Southwest, AZ
    Twinmax repair
    Anyone know where I can send my twinmax for service. Does not appear to be working?
    2004 R1150GS 1978 R75G/S Frankenbike
    AMA - BMWMOA - BMWRSOC - AZBEEMERS
    Gilbert, Arizona
    South Carolina
    can you contact the manfacturer? if you don't have the original box it came in with that info, I have mine and can send you the info.
    AKA SNAPGADGET
    Lifes too short to ride an ugly Motorcycle
    South Carolina
    also, have you checked the battery?
    AKA SNAPGADGET
    Mar 2007
    Quote Originally Posted by kgadley01 View Post
    The manufacturer is in France. I have emailed them en anglais but no reply. If you have an address in the US that will help.
    First thing I checked was the battery.
    Gilbert, Arizona
    Slow & Easy
    Dec 2005
    Austin, Tx
    What is your twinmax doing or not doing??? Does the meter light???
    Mar 2007
    Quote Originally Posted by Dave_Faria View Post
    When adjusting zero, there is no movement until one spot when the needle jumps all the way to the right. BTW I disconnected the light when I first got it.
    Gilbert, Arizona
    I dont know what I'm talking about but: This reminds me of the stereo reciever in my shop. The volume and balance adjustments got wonky from dust and moisture - no adjustment or jumpy volume levels etc. So I opened it up recently. Both knobs drive rheostats - variable resistors. I hosed each one down with CRC Electronics cleaner, worked them back and forth and blew it dry with compressed air (low pressure setting). Worked a charm. AOK now.
    So: you could open the TM and lookit. I'll bet the zero adjustment is a rheostat that compensates for changes in battery voltage level. You could hose it out with sumptin like CRC Electronics cleaner, dry it and then see if that changed anything.
    Oh, maybe test a corner of the TM someplace to ensure the Electronics cleaner does not attack the plastic box. I doubt it will but its probaly best to check. Be a shame to throw out the TM or spend the cost of a new one on repairs if it was really something simple like that.
    Slow & Easy
    Dec 2005
    Austin, Tx
    Ok on the light. I wonder if you've dropped or hit the zero adjustment?? Can you jiggle the zero knob at any position and make the meter jump??? The reason I'm asking is if the repair is not simple and you have to sent it to France for repair the postage will probably be very expensive. It might be cheaper to just buy another unit.
    Sep 2007
    So. Calif.
    I recommend opening the case and checking the two little vacuum hoses. One of mine had a small tear where it fit on the nipple. Replacing that hose "tuned up" my Twinmax.
    '14 R1200GS,
    Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
    Pressing #1 for English! tictac's Avatar
    Apr 2006
    SOUTH FLORIDA
    There are TWO good things about TwinMax.
    Hose A and Hose B
    The rest of the toy never worked right. You can get good reading but when you reverse the hoses, the reading is OFF.
    I have tried to find a repair shop with no luck and my rusty french was no help at all.
    Buy a 15ft of 1/8 clear tubing and attach it to the wooden yardstick.
    Fill the tubing with a couple of oz of Amoretto or good Irish Cream and you will have you self a nice Carb Synchronizer.
    Oh.. yes... both hoses from TwinMax attached to the tubing will do fine.
    Good luck.
    Registered User pawork's Avatar
    Oct 2007
    Savannah, GA
    Old thread, but I'm curious what the original poster did in the end. I did TB sync last week and had precisely the same problem with my Twinmax, which had worked fine for somewhere between 2-3 yrs.
    My solution was to buy some clear tube and build a manometer in about 20 min. Worked quite well and the bike is running very smoothly.
    2002 R1150RA
    1997 M3 Coupe
    Mar 2007
    Quote Originally Posted by pawork View Post
    I have tried to contact Twinmax twice got a reply once asking for details of what the unit is or is not doing. I replied but got no answer back.
    In the mean time I too made a cleartube manometer with ATF which works just fine.
    Gilbert, Arizona
    Registered User Daedalus214's Avatar
    Aug 2008
    Cary, IL
    Dwyer
    Since I have never performed a TB sync, and do not know the price for the Twinmax, this might not be relevant. There is a company called Dwyer, Michigan City, Indiana, which sells a variety of instrumentation to measure pressure, temperature, flow, etc... We use the company's Magnehelics, slack U-tube manometers, and inclined plate manometers all the time in industrial applications to determine flow (just add a pitot tube) and pressure.
    These instruments can be used to measure gauge or differential (which the TB sync requires I believe) pressure for almost any application. The only problem with using a fluid filled device is that if the vacuum is too strong, it could suck all the fluid out of the manometer; I do not know if the TB's vacuum is in inches of water or many mm of mercury. These are simple tools and the company sells a variety of hoses and fittings for connecting to equipment.
    As a side note, if you make your own manometer using clear tubing, a yardstick, and water, food coloring (red) can be added to give you a better visual. It does stain the tubing after a while and you'll have to get a new tube to see the levels correctly.
