Results 1 to 5 of 5
Thread: Easy way to install engine to frame?
    Registered User gertiektn's Avatar
    Aug 2009
    Ketchikan, Alaska
    Well, the frame is ready for the engine.
    All sweetly painted... now I want to avoid nicking it when I put the engine back in.
    This is where I am at. Engine is naked, no front cover, no top cover and no tranny attached. No carbs and no electrics. Starter is in place.
    So as I understand it ... from the left to the right, slight upward tilt on right jug and front canted down and it it goes. ??????
    I have wrapped the lower frame with cover to protect with a small terry cloth held in place with tyraps. I know about assembly, studs,spacers, kick stand, etc.
    Any pointers??
    Thanks,
    Jim
    Last edited by gertiektn; 04-09-2010 at 12:32 AM. Reason: needs to go to AirHeads.
    I like good stuff. No Chains here!
    1960 R50 -"Hanz"
    1977 R75/7 -"Gertie"
    2004 R1100s -"RFAR1"
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    I'm envious.
    I can't provide any direct experience, but had been told that the engine can also be 'rolled in' from the front, assuming you have not put the conn rods, pistons, jugs and studs in of course. That would seem to also imply a lighter heft which could help.
    I thought right to left, not left to right.
    Also, I've seen duct tape used to protect the frame. Seems like a cut up plastic 3-ring binder folder would provide protection and allow for some sliding versus the duct tape grabbing. Just thinking out loud.
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Hanz or Gertie?
    With or without cylinders?
    If Hanz with cylinders you want two people. If without cylinders it still helps to have two people. In either case have a jack with a flat surface in the opening in the frame where the oil pan will fit. Jack it up so it is just above the frame. That way you can slide the engine in above the frame then jack it down to install the lower engine mounts.
    If Gertie someone else will have to help.
    Nutfarm
    Apr 2008
    Folsom CA.
    Foam pipe insulation for 1" pipe. L to R, R to L, dos'nt make much difference, but I would get a buddy to help. Have all the studs and spacers ready.
    Ken G.
    Aug 2009
    Ketchikan, Alaska
    It's the Gertie.
    I will post a picture after I get it in.. Saturday am is the schedule.
    The engine is intact except the covers.
    I appreciate the tips. keep posting.. there is always a good idea out there.
    thanks
    jim
    1960 R50 -"Hanz"
