Results 1 to 6 of 6
Thread: What grips for BIG hands????
    Jul 2005
    I have big hands and I switched to those grips with the extended tab on them for putting the heel of your hand when cruising.
    problem is they keep creeping around the throttle assembly so i have to keep bending them back into position.
    I even tried grip cement.
    No good.
    Whats the desirable grip for guys with big hands?
    It's a /7
    Gerry
    Tiverton, RI
    Quote Originally Posted by puccini View Post
    No good.
    It's a /7
    Gerry
    http://www.casporttouring.com/store/...ory_Code=grips and this might help. http://store.bobsbmw.com/ProductDeta...roductCode=TR2 Good Luck
    www.OceanStateBMWriders.com
    Jul 2005
    Grips for big hands
    No
    That won't help.
    I don't have the original grips and the little speed tab isn't what I reall want.
    ANYONE HAVE A PAIR OF STOCK /7 GRIPS I CAN GET CHEAP?
    gERRY
    Aug 2009
    A guy I know told me he solved his big hands problem by finding an O-Ring that is slightly smaller than the grip and he added as many O-Rings as it took to fill the entire grip. This effectively increased the diameter of the grip and since he used a soft rubber O-Ring, there was less tendency for his glove to slip.
    Glenn
    2003 F650GS Dakar
    Registered User JerryAttrick's Avatar
    Dec 2008
    Tallahassee, FL
    Grip Puppies
    Check out "Grip Puppies". They are cheap, and they worked for me (6'6") on the K13GT with the pencil-thin grips.
    Also, consider Throttlemeister to give your right hand a break.
    JerryAttrick
    2013 K1600GTL, "Siegfried"
    But Mom, I've never found "well enough".
    Aug 2004
    SW Ohio
    Quote Originally Posted by JerryAttrick View Post
    +1 on grip puppies. I have xl hands too.
    2013 Triumph Trophy
    2007 R1200RT Broken driveshaft @ 54,000 miles. Come on BMW!
    2000 R1100rt sold @ 72,000 Great Bike!
    Iron Butt #24605
