Results 1 to 13 of 13
Thread: Airhead Tires
    Airhead Tires
    I have to replace the tires on my 1981 R100RT. I have only run Metzelers... any suggestions? Please include the brand and model and if you are happy with them.
    Avon Roadrunner (AM20/AM21) Motorcycle Tire
    Avon Roadrunner Motorcycle Tire
    link to web seller:
    http://traxms.com/Roadrunner.html
    I have these on my 1974 R75 available in inch sizes to fit the older airheads.
    My installer/ airhead guru recommended these - work great I am very happy.
    I do have metzerls (sp) on my other bike also good if you get the right size.
    Metric sizes are a problem with rubbing on drive shaft if you go with "its just a little larger than the inch size recommended"
    1974 R75/6 W Sidecar
    1989 R100GS
    Nutfarm
    Apr 2008
    Folsom CA.
    Michelin also makes the Macadams in the correct inch sizes. I have the Avons on a Norton I ride quite alot they work well.
    Ken G.
    Douglas Williams
    Mar 2006
    Raleigh, NC
    http://www.swmototires.com/index.php...hk=1&Itemid=53
    My tyres; my vendor; my bike, 1981 R100RT.
    Sent from a Galaxy, far, far away
    Unregistered User dduelin's Avatar
    Jan 2008
    N. FL
    My bike is 1981 R100. The past 4 years and 28,000 miles have been on Bridgestone S11 Spitfires in metric equivalent to inch size 100/90-19 and 110/90-18 sizes. No rubbing on fender brace or swing arm. Good traction in wet or dry, I ride to the right side of spirited. I get 10,000 miles out of a rear tire and who knows how much out of a front as I change them as a set.
    Dave
    R100
    ST1300
    Aug 2008
    North Carolina Coast
    Metzeler
    I have had my '93 R100RT for 1 1/2 years. I have worn out two Metzeler Lasertecs on the front in 8000 miles. I also wore out a rear Lasertec in 4000 miles.
    Changed to Metzeler ME88 on rear and have much better results (about 5000 miles now) and I have an Avon on the front. All tires were properly sized.
    Campbell Tellman II
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by 85K100LT View Post
    +1
    I now have ~500 miles on a new set on my '88 R100RT -- my 1st set of Avons in >30 years of riding. A good experience thus far.
    Now that the mold release compound is rubbed off I'm starting to push them a bit harder (after they've warmed up a bit, of course). So far, quite confidence inspiring, both leaning and under heavy braking; they seem to just grip, without any sense of squirming or other undesired drama.
    Living The Dream jewels's Avatar
    Nov 2009
    Albany, NY Area
    Avon Road Runner +2 Excellent on my 84 R80/RT
    1991 R100/RT - 1984 R100/RS
    2006 KZ-14/ Hannigan HP
    1980 R100/EML-1964 R69S
    2013 F800GT
    SGRIMSON
    what size Avons
    I have a '84 R80 RT and am interested in the Avons. What sizes did you get for yours? At a big bike show the rep was unsure of what would fit my bike.
    contact these guys
    Quote Originally Posted by 83014 View Post
    1989 R100GS
    Nov 2009
    Albany, NY Area
    Quote Originally Posted by sgrimson View Post
    Avon Road Runners AM20 come in the ORIGINAL size as was used on the bike from the factory (3.25H19 & 4.00H18).
    I put these on last year and am very satisfied with the tire...I do drive in the rain at times and find them better than most others.
    2013 F800GT
    keelerb
    I like Metzeler Lasertecs. Original sizing, good handling, good stick, ungodly wet-weather stick, and they look right for the bike (being I think the modern equivalents of the ME33 and ME99 the bike came with). FWIW/YMMV.
    Thanks to everyone for the replies! I've had this bike about five years and definitely want the best option.
