Results 1 to 9 of 9
Thread: Bi Xenon HID H4 Bulb Question
    Registered User saylorspond's Avatar
    May 2008
    Seltisberg, Switzerland (near Basel)
    Question Bi Xenon HID H4 Bulb Question
    To follow up on the recent discussion of HID light conversion kits, I have a general question for those who have installed a Bi-Xenon HID H4 bulb on an R1100RT or RS.
    After reading several forum discussions, I decided to purchase a kit from Xenon Depot (http://www.kbcarstuff.com/Motorcycle..._Kits_s/34.htm, Ontario). The quality of this set is excellent and the kit uses a Phillips bulb.
    One complication I have discovered, is caused by the new bulb's base thickness. Below I've attached a picture of the bulb from their web site.
    The polymer base is thicker than the usual metal H4 bulb base. As a result, the clamps do not lock down on the bulb base. While considering my options, I was trying to see if the clamp could be reversed and broke the plasic clip holding the hinge end of the clamp.
    So, does anyone have experience, or tips, on how to secure this bulb? Now that I have broken off the clamp, any suggestions on how to fix/rig the base to hold the bulb, without having to replace the entire light housing?
    Thanks for any
    Scott
    1995 R1100R (RIP); 1999 R1100RTP (sold); 2005 R1150R Rockster
    Nov 2005
    Calgary, Alberta
    Scott:
    I had one of these in my '02 1150 RS, but I had my tech instal it, so I can't say if he had any issues. From what I've read, it may be necessary to file the receptacle out a bit, to get the fit just right.
    If you've got all your old BMW News, there was an article by Paul Glaves a few years ago, on an instal he did on one of their bikes.
    Rinty
    May 2008
    Quote Originally Posted by rinty View Post
    Scott:
    Unfortunately, I think that article was before I joined. Do you, or anyone else, happen to recall which issue the article was in. Any suggestions as to repairing the clip "hinge?
    Scott
    criminaldesign
    the one installed was a bit thicker, but with a little steady pressure I was able to clamp the hinge in place
    Nov 2005
    Calgary, Alberta
    ...do you recall...
    Sorry, but that issue has been re-cycled. But I'll call my tech and see if he remembers how he did it.
    Rinty
    May 2008
    ... I'll call my tech and see if he remembers how he did it.
    That would be great. In the meantime, I found a replacement "light bucket" on eBay. Once it arrives, I will see what I can do to get the bulb to fit.
    Scott
    Registered User rmarkr's Avatar
    Mar 2007
    Lowcountry
    I have fitted 2 of the H4 bulbs and a couple of others where they should not have been fitted.
    I do recall making the "spring clip" from the (stainless) spring off of a rotary lawn sprinkler, and securing it with a small self tapping screw with a washer with the lip bent down.
    My K bike has a rotary type securing clip. The other possible issue is that the rubber boot will need modification or replacement, and clearance can be a problem due to the bulkiness of the Bi-xenon bulb housing.
    Mark
    "Of all the things I've lost, I miss my mind the most" Mark Twain
    May 2008
    Thumbs up
    FWIW, here is how I was able to seat the Bi-Xenon bulb. The Bi-Xenon base is made out of aluminum, allowing for easy filing. I filed down the tabs to seat the bulb better. I would have had to file considerably more to match the standard H4 bulb tab thickness. Instead, I reversed the bulb clip (since I had already broken the "hinge" this was easy) and attached a screw to hold the clip in place.
    Name:  HID Bi-Xenon Bulb Installation.jpg
    The rim of the bulb base is notched to accomodate the clip. I had to file one side (top right in the picture on the right), to allow enough room for the top clip to snap into the catch (hopefully this makes sense). I drilled a pilot hole for the screw, snapped the bulb in place and then added the screw and clip. This should be quite secure as the only way to remove the bulb is to either recess, or remove, the screw first.
    Scott
    Nov 2005
    Calgary, Alberta
    Scott:
    I spoke to my tech yesterday, and he confirmed that they just file them.
    Good wrenching!
    I think the Xenon upgrade in the Oilers is a good one, as the stock lighting is totally inadequate for daytime running light use (I don't ride at night). I've also had kits installed in two of our cars, that have poor lighting.
    Rinty
