Results 1 to 15 of 37
Thread: Gerbing Permanent Controller Install DIY
Hybrid View
    Aug 2008
    Kingston, NH
    The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
    The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
    It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
    Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
    This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    This DIY covers installing a Gerbing Permanent Controller on a KGT1300.
    Please note that the way I mounted the controller requires drilling of the side panel.
    It is a very straight foward connection process with or without a fuse panel.
    The connection process shown installs the controller to the Centech fuse panel. Note that the Gerbing's product provides a fused power connection.
    If you do not have a fuse panel you can still do this install, just connect the product directly to the battery terminals and you will not get any dash warnings.
    Aug 2008
    Kingston, NH
    This is what will be installed
    Aug 2008
    Kingston, NH
    Everything you need to install is provided by Gerbing with good instructions that are easy to follow
    Aug 2008
    Kingston, NH
    Preparation
    I removed the top and side plastic to have access to the work area.
    Please reference this link to remove the plastic
    The tools for this job were:
    • Small screw driver
    • Heat Shrink
    • Heat Gun
    • Electrical Crimp Type connectors
    • Wire wrap (optional)
    • Double sided tape (industrial grade)
    • Drill Bits
    • Electric Drill
    • Masking Tape
    • Caliper and ruler
    Aug 2008
    Kingston, NH
    Mounting location for the Main Controller
    Locate the controller under the platform supporting the ABS Unit - Clutch side
