Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Lasik vision correction & motorcycling
  1. #16
    I had lasek and it is the best thing I have done no regrets.
    Six years and counting
    I elected not to go with the monvision because it is nice to be able to read a street sign or see details of far away things, especially on a motorcycle. I also felt that when you get older your distance visions does not change or if it does it improves while your close up vision gets worse with time. I thought that the monovision would work for ahwile but may not last long. The advantage withmonvision correction is that you can always change it later. I am not so sure you can do it the other way.
    There are some things you have to accept getting older and reading glasses is one of them
  2. #17
    planepaul1949
    I am 60 with acute myopia (20/400+) and astigmatism, and always envied my 20/15 friends. I wore contacts for 40 years, both hard and soft. Contacts were becoming problematic, comfort wise. I went to Costco for an eye exam and some glasses for "around the house", as I never had a pair of glasses I could use for driving. Maybe it is modern materials, processes, or an optometrist who has insight, but the glasses were perfect. Greatly improved acuity and night vision relative to the contacts. I haven't worn a contact since.
    I have followed the various surgical procedures for decades, and still feel that my eyesight is not worth rolling the dice for in terms of potential downsides. I'll hapily go through the routine with the helmet and glasses for the kind of eyesight I enjoy (relatively) now.
    Paul in CA
    '05 R1200RT
  3. #18
    fritzl
    I had LASIK done in 2001 (Sept. 12... a memorable date for what didn't happen that day), and it's been great for me. The only side affect has been very minor halos during dark conditions, no worse than when I had dried out contacts.
    I was 29 at the time with -3.5 and -3.75 diopter corrections, which was pretty much the "sweet spot" for the procedure at the time.
    OP, at 58 you may not get the results that you want from laser surgery since the cornea has less elasticity and natural prescription changes might skew the outcome. Listen to your Dr. and make your own decision.
    F
  4. #19
    RK Ryder
    London, Ontario
    Quote Originally Posted by sudani View Post
    I tried the monovision with contacts to see how it would work. After about a week of being dizzy and feeling il all the time I decided it wasn't for me. I'll suffer with glasses.
    Same here. Over the years I have tried the monovision contacts, but I could never adjust to them. Bifocal glasses work fine for me, but I have found that bifocal contacts work quite well for riding, if not reading maps (carry a magnifier).
    Paul
    Knights of the Roundel #333
  5. #20
    Rodney Aiken Ctrod's Avatar
    Jan 2008
    Vernon CT
    Your eyes can‘«÷t be much worse then mine; I‘«÷m some where south of 200/400. I tried several helmet till I found one that worked well with my glasses, A Shoei modular helmet, and I have my glasses made with the reading part set very low in the glass or I have a pair that just correct for far away.
    I tried a pair of contact to show me what it would be like to have ‘«£Monvision‘«ō I hated it.
    I‘«÷d try new glasses first.
  6. #21
    Registered User jsoque's Avatar
    May 2008
    Long Island NY
    Lasik for 12 years and happy!
    Hi Piper Jim,
    I'm in the field, and had my lasik correction done in 1998.
    A true outdoorsman and spotter on a large sailing vessel, I was worried about halos and night time anomolies, but, thankfully, I've had none.
    Under a helmet, with glasses on, one can experience a bit of tunnel vision, and I don't anymore with my surgery.
    It's nice not having to worry about perspiration or a frame, gouging you at the temple, or on the nose bridge anymore, and my Scorpion EXO 1000 helmet has
    a flip down visor, and therefore, no more fumbling with insertin of sunglasses thru an opening in a FF helmet.
    I have to say that I don't think Monovision is the way to go. I would have to agree that stereopsis of having infinite vision, in both eyes is a necessity for one to remain an acomplished rider. Judging the distance to that curve in the road, or that small blemish in the highway, or obstacle, can mean the difference between a successful or unsuccessful turn, and continuing of your riding enjoyment.
    Most of my best judgements, at 60, 70, or 80 mph are made at closing distances of 300+ yards, and safe execution of your machine, under these circumstances is hallmark.
    Without the advent of stereo vision, you would be compromising yourself, your fellow riders, or your 2 up gal!
    As far as working your controls, we do this mostly in the dark already. Memorizing your signals, your releases, horn, and even the sound of your engine, all make you a skilled and proficient rider, and often don't need those visual cues to keep your bike on track, and out of harms way.
    If your corneas can handle some of the newest toric lenses for astigmatism, then, I suggest you give that a try for any astigmatic necessity.
    As far as running your electronics, stick to the basics, and turn the voice up on your Garmin, or your Tomtom, and listen for the turns coming up, so you don't lose your way. Leave the cell phone in your shirt pocket, and pick up the messages later, after you feel the thing vibrate.
    Anyway, don't give up the binocularity, it will prove to be your greatest adversary in the long run.
    Good Luck and Ride Safe,
    Jim
    (Emicon; that is my R/C J-3 on Floats)
    '10 R1200RT - Ostra Grey
    '04 R1150RT - New Life in Upstate N.Y.
    '04 R1150R - New Life in Virginia
  7. #22
    Nov 2005
    Calgary, Alberta
    My wife is an eye surgeon, but I haven't had refractive surgery done, because I don't want to have to bother with reading glasses.
    If, eventually, I need cataract surgery, I can opt for multifocal lens implants which will give me good distance and reading vision.
    I currently use Ray - Bans with progressive lenses, under a flip helmet, for riding. This combination works well.
    Rinty
  8. #23
    Feb 2010
    Colorado
    Lasik and motorcycling
    Thanks folks!!! It's very insightful to learn of your experiences and opinions. This is one of those decisions that is pretty much irreversible, so not to be entered into lightly.
    I appreciate the replies and will consider them thoroughly, along with a bit of soul-searching, to come up with a decision.
    Thanks again, great to get such great input on my question!!
    piperjim
    Piperjim
    '95 R1100RS "Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" Henry Ford
  9. #24
    +1 on the surgery
    I had both mine done in 97. No regrets at all. No more expensive glasses or sunglasses. One thing it does not do is reverse the ageing process. So if you were going to need reading glasses anyway that may not change, but i would make the same decision again today
  10. #25
    Feb 2005
    N. Dallas 'burb
    Very please with LASIK, even with minor complications.
    I had LASIK done on both eyes in November of 1997. I'm 98% happy with it. That small 2% is due to the flap not healing absolutely smoothly in one of my eyes. When that happens you develop a very slight astigmatism and shadowing. I rarely notice it. Its called "artificial astigmatism" and it can't be corrected.
    For me, it tends to crop up in two circumstances. One, is in darkened rooms looking at fine and bright images. The best example is watching a sporting event on TV and trying to read the score in fairly small font on the top or bottom of the screen. Sometimes, not always, that can be difficult to read because of the shadowing.
    The other time I notice it is reading very fine printing at some distance. I play in a symphony orchestra and I need the music quite a bit closer to me than I did with glasses. Its not a big deal, but it can be a problem if you have a stand partner (two players per stand) who also needs the music close. Have you ever watched a symphony and seen how far the bass players tend to be from their music? There's no way I could read that.
    The artificial astigmatism also made me fail my drivers' license vision test. In Texas you look into a little box and are asked to read fine font in a bright light, just like looking at scores on a TV screen. Its the exact kind of conditions affected by my artificial astigmatism. I see angles that aren't there. An "O" "C", or a "D" appear to have weird angles making them look polygon-ish, and all the letters had thick shadows. The test is really not applicable to driving, as I have no issues with reading signs, etc... I got a special state produced form filled out by my optometrist that overrides the failed test. It was no big deal, really. I was at my optometrist for a regular appointment and expressed my concern. He said I was fine for driving, whipped out the one page forum, and told me it would override the test if I failed. Worked like a charm. The form is designed for that very purpose: when the official test isn't adequate for actually testing how you see in driving conditions. My bet is that every state has something similar.
    That said, I'd get LASIK done again in a heartbeat, even with the slight artificial astigmatism that I have. My vision was so bad that I was literally attached to my glasses for all purposes. My diopters were over -8 in each eye, and I had terrible astigmatism. For me, LASIK was truly life changing.
    BTW, my wife had LASIK done seven or eight years ago, and her vision is perfect with no complications.
    Grant
    '05 R1200GS
    Former owner of an '03 R1150R
    BMWMOA #113847
  11. #26
    '91 K100LT, '99 R1100RT theblueeagle's Avatar
    May 2009
    Dry Western Colorado
    Question Wavefront custom lasik?
    Anyone ever had "custom" lasik? This is where they use the "wavefront" laser to sculpt the front of your eye instead of doing the flap thing. I've heard it is better with less problems than conventional lasik. I went in for a consultation but haven't decided on what to do. I'm fortunate enough I can see without glasses if necessary and could even drive in an emergency. My problem is I have terribly asigmatic eyes. Due to this I've always been forced to wear hard contacts or glasses. Lasik sounds like a great option but I'm leary of a mishap. I'm also concerned about loosing my very keen near vision.
    As for the monocular vision thing I see that way nomally. I had strabismus surgery in both eyes when I was a kid (yeah, I was goofy looking before that) and as a result was I can't cross my eyes. The other side effect is I nearly always switch hit my eyes. If one contact gets fuzzy I find myself unconsciously switching to the other. I suppose this would be how monocular vision would be if it was done right.
    Ride Safe - Be Safe
