Results 1 to 4 of 4
Thread: Saddle tear fix?
    Nov 2009
    Exclamation Saddle tear fix?
    I am repairing tears in my r90/6 saddle and I'm looking for suggestions on what glue/vinyl repair to use. I took the cover off and plan to patch form the back, then reinstall. What do you think?
    Yarddog
    For less than a hundred bux you can get a whole new cover...and it will look a LOT better than a patch!!! If you must patch, talk to your local upholsterer, I'm certain that she or he can do a much nicer job than you or I, but I'm thinkin' that it would cost dern near what a seat cover would cost...a seat cover for my R100/7 is only $70.00 from Sargeants...
    Tucson
    I agree and would just pony up for a new seat cover for $49.95 from Capital Cycle.
    According to them: Tailor-made covers match the original perfectly. Made in Great Britain. Thermoformed patterns (fluting) and pinstripe edges match exactly where appropriate.
    I've never seen one but I've got to think it would look better than repairs - which will probably split open again on hot day.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by RonKMiller View Post
    And while you are in there, get a correctly-formed replacement foam -- the 35-tear old stuff is long past due for replacement, and it's readily available. I don't shop Capital, but there are several vendors out there I would buy from, e.g., Sargent's for seat foam, Motobins.co.uk for the cover, many others.
    This is a pretty common question, and this site has a very good/efficient search engine - for topics like this, search is your friend!
