Results 1 to 9 of 9
Thread: Centech Fuse Panel DIY
    Aug 2008
    Kingston, NH
    New DIY here shows where I installed my Centech and the source for triggering the Centech control relay
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    Thank you taking the time to make a DIY. But for those of us not in the know, what is a Centech?
    Thanks,
    Scott
    1988 K75 Low Seat
    2009 R1200R Roadster
    Aug 2008
    Kingston, NH
    Scott - my apologies for not being clear. A Centech is a fuse panel you can mount on the bike to obtain power for powered accessories, lights, GPS etc.
    You can obtain the Centech as is, or you can also order a controlling relay.
    What I have shown is the Centech with controlling relay. What the relay does is it will provide power to the fuse panel only when the relay is energized. If you do not use the relay then when you install the fuse panel it will always be hot. There is no issue whether to install or not install a relay.
    I installed a relay so I do not have to remember to shut things off when I get off the bike.
    It is almost a requirement on any CanBus bike if you want to add a powered accesory and want to obtain power from the battery without causing fault lights to come on.
    ** NOTE on the CanBus - the CAnBus is the wire harness used in the bike which connects all the computers and sensors, the fault is actually detected by the ZFE (main Bike Computer) and throws the fault - usually for a noted increased load.
    The second it helps organize any additonal wiring of said accessories.
    You can also use it on non-CanBus electrical systems for the same reason of organization.
    Luis
    Last edited by Semper_Fi; 02-16-2010 at 01:47 PM. Reason: Additonal Information Added
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Jul 2007
    Evansville, WI
    But if you have only a farkle or two, you can just go to the battery and install an inline power fuse I assume? Except you wouldn't have a relay to automatically shut the farkles off....
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Aug 2008
    Kingston, NH
    Yes that is an option.
    But as you add more farkles.............
    2009 G450X White
    IBA #35651
    Rogue Moderator
    On the Road
    Dec 2003
    yooper land
    centech 11
    I've got the 11 it has two sides one power on always,and one switched,works pretty good that way
    Aug 2008
    Kingston, NH
    Did a search on Centech 11 no luck - you got a link - want to check it out
    2009 G450X White
    IBA #35651
    Rogue Moderator
    On the Road
    Dec 2003
    yooper land
    centech ap2
    try this scroll down the page a little
    http://www.cyclegadgets.com/Products...t.asp?Item=CEN
    latter Doug
    Aug 2008
    Kingston, NH
    Got it - thanks
    2009 G450X White
    IBA #35651
    Rogue Moderator
