Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 77
Thread: Lifting bike onto Centerstand
    This question has probably been asked too many times, but I need to ask it again. How do I best lift the bike onto the centerstand without dropping it . Last fall I almost lost it. There is a gadget ( bike lift by Wunderlich) for sale which attaches to the side of the bike and is supposed to help im lifting it on the centerstand. Is this worth it? Has anyone tried it.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Tom,
    Yes, it has been asked a few times...search is your friend! LOL
    As far as putting it on the stand, I really don't think with the propper techinique you will reallly need any additional equipment.
    First, put the stand down to the ground with your right foot on it, and rock the bike side to side slightly. You will be able to feel when both "feet" of the centerstand are touching the ground.
    Now, holding the bike by the left handgrip, and the handhold really put all of your weight on the back piece of the centerstand while pulling slightly up and back with the handhold. It really should take almost no effort of lifting with your arms.
    With a little practice, you will get it!
    460
    -Albert Eienstein
    with BMWs, it's really more a matter of pushing the centerstand down into the ground than it is pulling the bike up above it. PUSH the c-stand down with your foot.
    Sep 2009
    Chestnut Hill, MA
    +1. I tend the think of it as an elementary physics problem: 1) push the stand down to the pavement with your right foot, then rock it just a little bit to make sure both sides are touching the pavement, 2) hold left handgrip with left hand, and (depending on model) hold, handgrip (R1150RT), luggage rack (R1200RT) with right hand, and finally 3) using the handholds only to guide the motorcycle towards the rear, step down smartly (putting your entire body weight onto it)on the centerstand footpad.
    I weigh 228#, and my final step (#3) has to be moderated, as otherwise, I'd launch my R1200RT back, and it would fall off the stand.
    Don't try this barefooted...probably won't work...
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    RK Ryder
    London, Ontario
    The above instructions are the way to do the lift.
    However, if you should ever lower the bike's suspension, it will require more grunt to get the the bike up. If in time it becomes more difficult to do the operation, it might be an indication that the rear shock needs replacing.
    Paul
    Knights of the Roundel #333
    Quote Originally Posted by ExGMan View Post
    actually, my R11S is so easy, i have done it barefooted. smarts a bit, but certainly doable. My F800GS is not quite that pleasant, especially with saddlebags on it.
    Wilmington, NC
    Well here's a twist on the technique that makes it even easier- I do this because I shattered the long tendon in my right foot and cannot put focussed loads on that arch without starting swelling, even with boots on. Turns out its less effort than a right foot technique anyway
    Put the stand down and make sure both sides are touching hard stuff
    Turn bars all the way to left (clutch side)
    With LEFT foot on the stand, right hand on the bike by the rear seat and left hand on the left grip, simply ROLL the bike rearward onto the stand.
    Yes it is NOT about lifting the weight of the bike and
    Yes you need to be careful about being over exuberant, especially if you've got a fully loaded top case! It can get some pretty serious momentum going. If your technique is sound it almost jumps up on the stand.
    I should probably point out my stand is on a "turn a bike" so I spin it 180 next.
    So. California
    It also helps to have the handlebars turned slightly to the right when getting on or off centerstand, this will cause the bike to lean towards you rather than away from you preventing a tip over.
    Aug 2004
    SW Ohio
    I use the wunderlich handle when I can't use the handhold by the rear seat because I have a large duffle strapped to the seat.
    2013 Triumph Trophy
    2007 R1200RT Broken driveshaft @ 54,000 miles. Come on BMW!
    2000 R1100rt sold @ 72,000 Great Bike!
    Iron Butt #24605
    Feb 2007
    Southern Delaware
    My sense is if you are almost losing it while placing it on the center stand you are not getting the full weight of the bike square on both feet of the stand. As others have stated here, it is more technique than it is strength.
    Canon City Colorado
    Experience is the best teacher
    Remember the "old" days, when the Honda C-110 Super Sport weighed in at 150 lbs. and you where in 9th. grade at 135 lbs. No side stand and you learned the technique. As we grew up and our bikes got bigger, larger, heavier and faster we drew back on that experience and evolved without really thinking about it.
    Now the bikes are 400 plus lbs. and we "I" am over 60 years old and I pop up the GSA without thinking.
    Keys: 1. Keep working out. The strength you keep adds confidence.
    2. Start small. Practice on a smaller lighter bike.
    3. Never hurts to have a spotter until you perfect the technique.
    4. The advice on previous reply's are perfect.
    Just like riding a bike. Once you learn it, it becomes second nature.
    Camas Valley Oregon
    It's easier to put it up on the center stand than to take it off IMHO. I always make sure the side stand is down and standing on the left side of the bike with it in first gear I rock it forward and "bounce" it off the center stand. Being in gear stops its forward motion and I preload it to the left so it winds up on the side stand.
    Tremont, IL
    My GSA has got to be one of the easiest bikes ever to put on center stand. As said above, just step down on the centerstand. I also gently pull up on the bike, but that is more to control the bike than anything else. Once you do it a few times you will get the hang of it.
    Registered User widebmw's Avatar
    Reno, NV
    Quote Originally Posted by badgertom View Post
    I checked the OP's previous posts and saw that he has a R1200R.
    I looked at a R1200R at a dealer and put it up on the center stand and compared to the other models it is not as easy as a RT or a GS.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by MPMARTY View Post
    Interesting -- I always make sure my sidestand is *never* down.
    The reason is that I am more concerned about the suspension allowing the bike to drop down far enough that the sidestand hits before the bike is finished coming down, and immediately throwing the bike over to the right (a motion there's no way I could ever hope to stop), than I am about whether I can hold the bike upright (with the sidestand up) as the bike comes off the stand.
    Just sumthin' to ponder.
