Results 1 to 12 of 12
Thread: electronic devises
    Oct 2005
    electronic devises
    Has anyone set up a system to charge electronic devises on the bike? My cell has a cord to plug into a cigar lighter, my MP3 has a USB cord. Is there any way that I can recharge these from by bike (stock 600cc US)
    You stupid, fix it! r11rs94's Avatar
    Tiverton, RI
    Quote Originally Posted by 72598 View Post
    Yes, I charge my cell phone while riding.
    The thing about traveling is, you never want it to end and you can't wait to get home.
    I answer to Roy, Chief, or Sarg.
    04 R-1150-RT current bike. 94 R-1100-RS74,383, Sold, 78 R-80/7, K.I.A by a D.U.I
    www.OceanStateBMWriders.com
    RK Ryder
    London, Ontario
    Quote Originally Posted by r11rs94 View Post
    or when camping, overnight when the bike is sleeping (lock phone in tail section. The bike has always started in the morning.
    Paul
    Forest City Motorrad Club #159 - Treasurer
    Knights of the Roundel #333
    Oct 2005
    I guess I need to reword.
    Is there any problems just wiring up a auto type cigar lighter socket to bike to charge cell or will the lower voltage of the 600 be a problem?
    Is there any way to charge a MP3 from a bike? (USB cord)
    Toadmanor
    Look at Powerlet merchandise you can but from them or from Eastern Beaver.
    Calgary
    I use a powerlet socket wired into my tankbag to charge my assortment of battery operated electronics.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Powerlet to Cig Lighter Adapter will take care of your cell phone. Then get something like this (found by googling usb power adapter)
    Canada and the Alps
    The size of the bike has nothing to do with it; you either have a 6 or 12 volt system...in your case, you have a 12V system.
    Just wire in a cigarette lighter to the battery terminals. I got mine at radio Shack.
    See that thing held on to the bottom of my instrument panel using 3M Dual Lock? That is my cigarette lighter that powers my GPS, charges my cell phone, etc.
    To power your USB, get a cigarette lighter plug with a USB slot in the end available at GPS City.
    Oct 2005
    Global Rider by lower voltage on the 600 I did mean 6V my 900 is 12V. (Because they are so rare that I forgot they made 600cc /5 and /6) I have used a simular set up, for cell, on the ole 900 and was wondering if it would hurt electronics with the 600 being lower (6V or 1/2) voltage. Haven't charged MP3 on either yet.
    Aug 2009
    I have a BMW 24 inch adapter with a BMW Accessory Plug on one end and the a cigarette lighter socket on the other end. They also make a shorter version of the same thing. I use it to charge my 2 cell phones at the same time using a $3 adapter from an auto parts store that has a cigarette lighter plug with 2 wires coming out of it and a cigarette lighter socket on each wire. It only takes about an hour to charge both up to full charge, so I do this while sitting around the campfire just before turning in. You will need to get a USB car adapter, available cheaply on the internet.
    Glenn
    2003 F650GS Dakar
    rocketman
    doing a quick search it looks like most cell phones, ipods, etc actually use 5 volts for charging, (at least thru the USB port) not 12 so the 12 volt changing adpters for cig lighters actually step down the voltage. Depending on how they do it (solid state or transformer coil) it *should* work. Perhaps a bit slower. I think that is what you were asking? Also perhaps the question of whether it will drain the battery? With a good charge I shouldn't think so, those devices use very little amperage, and that is what would drain the battery, not voltage per se, if I remember my electrical theroy right.
    RM
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Quote Originally Posted by MCMXCIVRS View Post
    I do the same as Ed.
    I have a fused SAE plug coming off the battery (use this connection for battery charging- off season). I put together an adapter that plugs into the SAE plug, goes thru the electric pass port into my tank bag and it terminates as a female cigarette outlet. There I can plug in the cell phone charger, iPod charger or intercom charger- This year I want to get a triple outlet adapter so I can charge all 3 at once.
    You have PLENTY of "juice" to run any small charger/adapter.
    Good luck.
    John
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    '12 Suzuki DRZ400
    ("kid's" bikes) '02 Kaw ZX6R- Jen's '07 Duc 800ss- Johnnie's
