Results 1 to 6 of 6
Thread: Wheel Bearing Seal Replacement Interval?
    Monza Blue 1974 R90/6
    Delaware
    I'm like a one trick pony lately because I've been focused on greasing the wheel bearings myself rather than my usual stunt of having the dealer do it during tire replacement.
    Thanks to last week's thread, I got the disassembly figured out (front and rear) and ordered the "gizmo" from Cycle Works to get grease into the one bearing that is trapped on the spline side of my rear wheel hub.
    Any opinions on how often the seals need to be replaced? They are $15 apiece, so that is $50 if you include $5 for the gasket that goes under the cover (rear hub, opposite from the spline side, held on by five bolts).
    If they are not leaking grease (out) and it doesn't look like water is getting in (to the bearings), don't bother replacing (check again next tire change); or, change them regardless?
    Barron
    Northern Front Range, CO
    i'd vote with "if it ain't broke, don't fix it". the job of a seal is to seal. if it's doing it's job, why fire it, just to hire another one just like it to do the same job the last one was doing?
    Ride Safe, Ride Lots
    Registered User amiles's Avatar
    Jul 2003
    Murrells Inlet, S. C.
    I believe that the official policy is that these be replaced EVERY time that they are removed.
    Yarddog
    The official factory policy is to make money and lots of it!! LOL Normally, I'd be the OCD kinda guy that would replace them every time. However, $15 a pop is stupid. I had the same question for my shop, and they said don't bother unless they leak or are damaged. It would be different if the dern things were five bucks a crack or less, but they ain't all that hard to replace, at least on my bike...
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    I agree. You're gaining nothing if you're replacing good with good.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    TGHSMITH
    I clean and check mine, but also keep a new set stored on the bike.
