Results 1 to 12 of 12
Thread: Helmet Lock
    Maplebliss
    Helmet Lock
    Is there a helmet lock on the 2002 R1150RT? If so, forgive my ignorance, but I can't find it. If not, what are good solutions other than pegs and handle bars? Any aftermarket devices? Thanks
    Apr 2005
    Seattle
    I have an 03 1150R (not RT) and mine is near the seat lock.
    Don
    South Carolina
    Quote Originally Posted by Maplebliss View Post
    On my 99 RT there's one on each side of the rear seat. they are funny looking metal loops. I've had my bike for two years and just found out a couple weeks ago what they were for... PS they're mounted to the frame...
    AKA SNAPGADGET
    rabid reader dbrick's Avatar
    Santa Cruz CA
    The RS has similar wire loops, accessible when the passenger seat is lifted. The problem is that the helmet strap from a fullface helmet is only long enough to permit locking if the helmet is handing next to the seat; the strap isn't long enough to permit locking if the saddlebags are in place, or if you want to put the helmet on top of the seat.
    I had my brother-in-law (he had a bicycle shop at the time) form two loops on the ends of a piece of plastic-covered wire rope. The end-to-end length is about 12", and the loops are each about 2" long. I run this around the chinbar, push one end of the wire rope through the other, and there's enough length for the free end to fit over the bike's helmet loop. The helmet rests on top of the saddelbag. The wire rope stores in the tail compartment.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Victoria, BC, Canada
    I bought a snow board lock. It has a combination and about four feet of cable. I run the cable through the openning of my full face helmet and then lock the lock around the luggage rack or the helmet locks under the seat. I also make sure the cable is as short as possible to reduce the amount someone could get at with cutters, and I try to get the cominbation section out of sight. Maybe I am just paranoid! I can lock two helmets with this or run the cable through the sleeve of a jacket and lock it as well. This has served me well on two BMWs over several years.
    South Carolina
    if you go to your local Police or Sherriff Dept. and ask for a gun lock, most will give it to you free. mine is aprox. 12" long and works great for locking a Helmet...
    AKA SNAPGADGET
    Jeffhorn
    My 2002 RT has an after-market helmet lock at the license plate.
    maacova maacova's Avatar
    Richmond, VA
    Helmet Lock extension
    I went to Lowe's and got 2-14 inch pieces of small (I think 3/32) aircraft cable and 4 double hole swage fittings that you smash with a special tool (hammer in my case). Not pretty but do the job. Cost about a dollar each so the price was within my range. Make sure you keep the cut ends of cable inside the swage fitting so they can't seperate and poke a hole in your hand. I just slide them under the rubber band that holds the tool kit for storage under the back seat. They are always there when I need them.
    Richmond, VA
    Helmet Lock Extension
    Second shot of cable through D rings in helmet and hanging from lock. Just add rear seat. Will it stop every thief? No, but it will slow them down. Easier to cut helmet strap with knife than to cut my cable.
    Registered User d martin's Avatar
    Dec 2007
    "The Gas City" SE Alberta
    Helemt Locks
    Sierra BMW sells LidLoc that locks helmets to the BMW side hard cases.
    TANDEMGEEK
    I've found that for short absences I can close the long end of my Shoei helmet's chin straps (which have a small plastic tab that's used to tie up the loose end) under the system case handles and either sit the helmet on the pillion's seat, the case or let it hang forward on the case by the strap. Once the system case is locked with the handle down, the strap can't be removed.
    RK Ryder
    London, Ontario
    Quote Originally Posted by maacova View Post
    This systems works well unless you are touring with a tent strapped across the passenger seat. I have a similar cable made up at Home Depot that is permanently strapped and locked to the helmet lock and footpeg holder on my old '87 K. It is always available, even when the tent is strapped to the rear seat. I wish BMW had come up with a similar locking mechanism with the R1100s.
    Paul
    Knights of the Roundel #333
