Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 105
Thread: Your speed in the twisties
  1. #16
    Manfred
    All the tips about how to not kill one's self are great. I benefited from this book, though much of the content was stuff I already knew - simply had never applied.
  2. #17
    Jul 2007
    THE BIG SKY
    Treat every unknown, blind cornor as a decreasing radius turn. Enter as wide as safely possible; commit as late as possible to the apex. Has worked for me.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  3. #18
    South Carolina
    most of what everyone has already said is good advice. I would like to coment on your where to look question. when racing I was taught to look threw your turn. otherwise look where you want to go. always leave yourself a way out incase something unexpected happens. on a left turn, I try to enter the turn as close to the center of the road as possible. do not touch the center line. that paint can be slippery and can put you down. entering near the center on a left turn and to the right on right turn gives you room to adjust if you need to. be carefull....
    AKA SNAPGADGET
    Lifes too short to ride an ugly Motorcycle
  4. #19
    BUBBAZANETTI
    Quote Originally Posted by Sue View Post
    He used to say that if the speed limit sign is in the teens, then that actually means as FAST AS YOU CAN GO in first gear. If the sign is in the twenties, then that actually means AS FAST AS YOU CAN GO in second gear. And so on...
    cool, i'll hop on my R1 and hit that 15 mph decreasing radius turn at about 97.
  5. #20
    Apr 2006
    Like many have already said, signs mean nothing, in fact I NEVER look for them and 99% of the time I don't consciously see them.
    I am looking at the corner and road conditions as I approach, but before my turn in am looking as far down the road as I can see, sometimes it is even 2 or 3 corners ahead.
    The big mistake most make is looking 50' ahead of the bike, looking for hazards, apexes and exit points. That is way to close, and way to late to do anything about it, in fact is you try to react at the last second, you will probably make it worse.
    I learned from skiing the bumps that the brain will remember points you picked out moments before, so you always look 4 or 5 bumps ahead. For those that don't ski, think about hopping on rocks across a stream, do you look at your feet to make sure it lands on the intended place, or do you look ahead 3 or 4 or more steps ahead and pick the path and your feet magically land just where you wanted them to? Riding is the same, I am sizing up the next corner as I hit my turn in, apex, and exit points with out even thinking about it.
    SMOOTH was mentioned and that IS the key to riding quick, to do this looking ahead is critical.
    Personally I am a slow in fast out guy, Nick Ienatsch, Keith Code and others preach this technique, it gives you more time to react to something unexpected, and since you are usually accelerating through the corner gives you higher exit speed to get to the next corner quicker.
    Also at least on the boxers when running spirited I am in the 4000+ RPM range. By being in a lower gear the only speed control you usually need is the throttle, even though I am pretty quick in technical tight stuff, I seldom use the brakes. I look at it this way, I want my brain processing as far ahead as it can so if I don't add brakes and clutch to the process, more of my gray matter CPU resources are available fo it.
    BTW Sport Riding Techniques by Nick Ienatsch is a good book, I can't say I learned a lot as I already practiced much of what he preached, but it reinforced what I was already doing.
    And find your closest track day, you will learn more in one day than you would riding the street for a year.
  6. #21
    As far as I'm concerned the critical factor is sight distance and braking distance. There is a huge difference in my speeds in the woods in Arkansas compared to my speeds here in the Texas Big Bend. In the woods, sight distance around/through the corner is often limited while here it is often the case that sight distance is a long way through the corner even when the geometry of the curves are the same.
    The other factor is that different states, and in some states different counties apparently use more conservative or less conservative criteria is posting those advisory signs. I normally judge corners without really looking at my speedometer, but the ones that say 10 or 15 or even 20 usually cause me to check my entry speed with the speedo.
  7. #22
    BUBBAZANETTI
    ditto
    the 40-45 corner advisory in a 55 zone does not result in me lowering my speed at all and more than likely results in an increased speed as i know i am getting a good sweeper. it's the slow WAY down to less than 50 percent of the avg posted speed tight turns that require more attention.
  8. #23
    Quote Originally Posted by Greenwald View Post
    Here's what I would suggest: First, forget about any 'ideal or target speed.'
    Speed will be determined by your technique and level of experience.
    But I understand your curiousity: You are approaching a new curve for the first time, and want to enjoy the experience of negotiating it on a motorcycle, safely but with a little 'thrill factor' tossed in. Very understandable.
    As you approach a new curve that looks like fun, dump much of your 'approach speed' (assuming you have distanced yourself from tailgators), and (this part is crucial) make sure you position your front tire on the 'outside' of the curve as you enter it.
    That way, you can drift inward thru the curve (which might be towards a shoulder or a centerline, depending on the type of curve), and gently roll on the throttle to achieve the max velocity that conditions will tolerate.
    Then let centrifugal force cause you to exit the curve again on its outside edge. "Always be looking where you want to go; don't be lookin' around at where you are - you're already there." Remember: The bike obeys the body; the body obeys the brain; the brain obeys the eyes.
    Outside - Inside - Outside: the perfect path of travel for any curve. Smooth is fast.
    Slowing down may not feel like what you want to do to achieve that 'thrill factor,' but as you learn to roll on the throttle more confidently with each opportunity to practice negotiating curves, you will be amazed at your speed.
    If speed gets away from you in a curve, do not brake (braking when a bike is not perpendicular to the ground has its own vicious penalty!), but simply roll off the throttle and lean a bit more away from the direction you do not wish to go - it works.
    Give these methods a consistent workout next time you have twisties to play with, and amaze yourself!
  9. #24
    Aug 2003
    Marion,Ar.
    Been riding the twisties just north of Memphis, Tn., close to the Mississippi River on the Chickasaw Bluffs. Lots of short tight turns. Road surrounded by many small farms with livestock, interspersed with stands of trees and intercrossed with many small streams and creeks. Lots of debris in the roads which seems to accumulate in the turns. That combined with the short sight distance keeps my speed at a manageable pace. Really been digging it.
  10. #25
    Quote Originally Posted by BubbaZanetti View Post
    In my truck, it means 15 over.. on the motorcycle... 25?
  11. #26
    great post.
    countersteering adds to the magic, too.
  12. #27
    BUBBAZANETTI
    Quote Originally Posted by Visian View Post
    great post.
    ever since i became a Rider Coach I find myself doing the O-I-O routine in my fiancee's CAR.
  13. #28
    murphychuck
    Living in the far west corner of NC,I have no choice,but to ride the twisties! I've always looked at posted speed signs on curves to be for cars and trucks. That said I usually run at about 10-20 miles over the sign. Every turn is different and unless it is one I regularly travel I am very cautious about how I approach each new curve. I've found out that the further back I'm on my seat,the better I can do the serious twisties around here! My favorite roads near my home are Rt 68 in TN,Rt 60 in Ga. and Rt 28 in Nc.
  14. #29
    when it's on two wheels, i take it!
  15. #30
    Bikes, Guitars, and ... beemokat's Avatar
    Jan 2005
    Ann Arbor, MI
    Quote Originally Posted by murphychuck View Post
    Real twisties being hard to find in MI, I take it easy when I'm in your part of the country. But don't worry, I'll move over and let you by.
    Wherever you go, there you are.
