Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: After market windshields on K1200GT
    jamespyke
    Cool After market windshields on K1200GT
    I have tried the original BMW stock windshield. Noisy (I never wore earplugs before), lots of wind in the eyes (I wear a modular helmet but prefer the shield open with sunglasses) and the passenger finds more wind "pushing her around". So I tried a CeeBailey 2"taller and 4" wider windshield. Same noise problem, If I run with the windshield full up I end up looking through the windshield (not what I want), somewhere in the middle of the range seems to work best but still much windier on the arms and elbows. Neither seems to create a pocket of calm air to ride in. Previous bike was an FJR1300 with the CeeBailey taller and wider windshield. We both wore 1/2 helmets and never wore earplugs or face shields. Help, I need to get this problem solved to enjoy this bike.
    Jim
    Charlotte NC
    Jul 2007
    Evansville, WI
    Your height and inseam might help, so others of similar stature can say what works for them.
    Gilly
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    jamespyke
    Height and Inseam
    Ok 6'2" and inseam of 31"
    Jul 2007
    Evansville, WI
    Hopefully someone taller chimes in. I am 5'9" and a 31 inseam, so I am riding a lot lower than you are.
    Gilly
    13 C650GT
    MOA 44606
    Aug 2008
    Kingston, NH
    You may want to check out aeroflow - here is the link Aeroflow Link
    If i were to go from stock I would check these guys out first.
    I ride solo, as my wife has her own bike, but would like to see a little less turbulance.
    Also have a modular helmet but ride with the faceshield open to crakced depending on temps
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Registered User cjcs's Avatar
    Nov 2009
    South Orange Co. Ca.
    After Market Windshields
    I've also got the CeeBaileys windshield on my GT mostly because I have their shield on
    my R1100RT. What a mistake on the GT. Like you To much wind noise in any position and looking through it when it's all the way up.
    I recently meet a rider with the aeroflow shield and comparing the two shields, the aeroflow has the required flip at the top, the sides are tapered towards the top and it
    just looks more fitting on the GT. imo.
    Carl
    BMWMOA 11500
    Registered User JerryAttrick's Avatar
    Dec 2008
    Tallahassee, FL
    I'm 6'6", with 35" inseam and I'm not planning to change the windshield at all. What might be different is that I have the bars adjusted all the way down, placing my head lower and more forward. (flashbacks of '70s cafe racers)
    I'm looking just over the top of the windshield when it is full up. Using a full coverage helmet, I leave the visor open at all speeds below highway, even though my eyes are very wind sensitive.
    On an R1150 (just sold) and an R1150RT, we had/have the Parabellum +4", and they both worked for us.
    JerryAttrick
    2013 K1600GTL, "Siegfried"
    But Mom, I've never found "well enough".
    jamespyke
    Cool Aftermarket Windshields for 1200GT
    Thanks for all of your replies so far. Has anyone ever tried modifiying a windshield, by placing it in the oven and altering the lip on the top?? I know it can be done and you need a big enough oven, the right temperature and some sort of tool to work with. Real good pair of oven mitts are a must too. As I have ridden along, I sometimes (with the cruise on) hold both my hands over the top edge of the stock windshield angled forward about 45 degrees from the stock shield and it is perfectly quite. It seems to me that if I could mold a kick-out to the top of the shield that would be the trick.
    Comments??
    tourist
    Putting your windshield in the oven would not be good. That's only my opinion.
    I have a 1300gt with the adjustable windshield. I'm also 6' not sure of my inseam but my legs look normal. I bought a deflector from some where but it looked stupid so I took the mounts off it and bought a couple pieces of acrylic. One piece had the same coating as the windshield and the other was the "plain" acrylic. After cutting the pieces to the shape I put them in the oven. I tried to match the curvature of the windshield. Both pieces have what I would call micro cracks, super fine lines the can only be seen in the sun and at the right angle. The clarity of the pieces also decreased sightly.
    But the wind deflection is what I was after and it works great. I can also lower the windshield and easily look over with very little noise.
    Registered User Chris_d's Avatar
    May 2006
    Near Toronto, Ontario
    I'm 6' 5" and bought a K1200GT fitted with a ZTechnik screen. The noise was torture with a System 5 and custom earplugs with any position of screen or handlebars.
    Went back to stock which was a little better but not great. Switched to a Wunderlich lower screen which is much better. Raising the seat up some more put me into the comfort zone.
    My experience has always been to go lower and get my head into some clean air,
    not higher sitting behind a 'sail'. FWIW!
    Jul 2007
    Evansville, WI
    Re altering the top lip, isn't there a company that makes a foil of some type that would do this? I can't remember if it would work on "any" stock windshield, or you may need to buy that particular companies windshield. Either clamps to the top or there are holes in this companies' 'shield which allow it to be attached and as I recall it can be adjusted for angle.
    Of course the Cee Bailey already has what you are talking about, the small flip on top, and they have many different sizes. Be sure to research what these companies consider the "stock" height though. The US has a slightly taller 'shield than "the rest of the world", so if you order a +2 for example, make sure it is actually 2" taller than you have right now. You can probably order a Cee B and be pretty happy with it if it is ordered correctly, many height/width options.
    Gilly
    13 C650GT
    MOA 44606
    Jul 2007
    Evansville, WI
    Quote Originally Posted by chris_d View Post
    I find this to be true, also. I have 2 good areas; head down low (typical BMW semi-tuck position) and screen all the way up (good for cold weather).
    OR screen all the way down, and a more upright posture, BUT with my old Synchrotec helmet, I have to have the visor opened, it is then very quiet as well. With the visor shut, I really "need" the earplugs. If I forgot to put in earplugs, I really need to have the visor open or the noise is tremendous. Luckily I wear glasses so my eyes are protected.
    A little hassle, the bike makes up for it in other ways.
    13 C650GT
    MOA 44606
    jamespyke
    Cool AeroFlow
    For anybody out there with the Aeroflow screen. Do you have the small deflectors also? Do you look over or through the screen?
    Thanks Jim
    Jul 2007
    Evansville, WI
    I PMed Jim seperately, it is the Laminar Lip addition that I was thinking of:
    http://www.laminarlip.com/k1200gt.php
    13 C650GT
    MOA 44606
    jamespyke
    Cool Responses and Summary
    Thanks all for your suggestions. I have sent an email to Aeroflow and I think I would like to try one of their systems. As posted by others, its not only that the screen needs to be bigger, wider, taller but that it needs to have a different shape at the top to do its job. I've seen the add on deflector and maybe it works dunno, but like I said I think I will pursue the Aeroflow for now. Their system looks like an integrated deflector as they are separating the air stream and throwing it over your head. It surprises me that I seem to be one of the few that is not impressed with the comfort and protection provided by the standard screen or the CeeBailey, maybe you guys have never experienced how peaceful and quite a ride can be, behind a good screen. And I don't mean a barn door........For the life of me I can't imagine riding sans helmet at any speed with the present screens.
    Jim
