Page 4 of 10 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 150
Thread: Harbor Freight Motorcycle Lift
  1. #46
    Nov 2003
    Dartmouth, Massachusetts
    Now cut a hole in the floor so you can flush mount your lift!
    http://public.fotki.com/Rbertalotto/...ycle-lift-ins/
    I needed to do this as I store a cor over the lift and the lift on the floor was to high.
    RoyB....
    2007 BMW K1200R Sport (abs),2007 Suzuki dl650 V Strom (abs),2004 Honda VFR (abs),1972 Honda Trail 90,
    2001 Moto Guzzi V-11 Rosso Mandello
  2. #47
    May 2007
    Raleigh, NC
    That is intense! I see some nice toys in there including the Oxy/Acetylene welder. We need a "show your shop" post. I'm more interested in your tools and shop than the hole!
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
  3. #48
    South Carolina
    now thats a great Idea...
    AKA SNAPGADGET
  4. #49
    Nov 2003
    Here ya go
    http://public.fotki.com/Rbertalotto/...tool/man-cave/
    More here:
    http://public.fotki.com/Rbertalotto/machine_tool/
    I love welding.....The shop has O/A, MIG and TIG........."Welding is knitting for men!"
    RoyB....
  5. #50
    South Carolina
    Very nice, I have one less bike and no Porshe. but other wise looks alot like my man cave. Kenny...
    AKA SNAPGADGET
  6. #51
    Registered User KALTZG's Avatar
    Aug 2004
    Crestview, Florida
    Mod for extending the front wheel stop
    I dont use the front wheel vice. I use the center stand. When I roll the bike onto the lift and put it on the center stand the bike pulls back 11 inches which moves the bike back past the center point of the lift. I fabricated this front wheel stop to extend the stop 11 inches forward so that when the bike pulls back when put on the center stand it is more toward the center of the lift.
    Gail Kaltz
    1997 GS
  7. #52
    Aug 2004
    Crestview, Florida
    The angle iron on the underside provides reinforcement for the lift surface.
    Gail Kaltz
    1997 GS
  8. #53
    Tucson, AZ
    That is a good idea, and very cool. You must be a welder!
    Quote Originally Posted by Kaltzg View Post
    Jeff Dean − BMW MOA Co-founder (1972)
    '15 R1200RT, '15 R1200R, '07 R1200RT, '67 R60/2, '55 R67/3, '54 R51/3, '54 R68, '49 R24
  9. #54
    Aug 2004
    Crestview, Florida
    No welding necessary
    Quote Originally Posted by bmwdean View Post
    Thanks, and I have been a welder by trade, but this mod can be done with a drill and a hack saw. The only welded part is visible from the first picture. I welded the wheel support pieces to the angle iron brackets, but there is no need to weld. Actually, those two pieces could be pop riveted in place.(any thing to keep them from moving around) The strength comes from the angle iron and the support from the bottom piece.
    Gail Kaltz
    1997 GS
  10. #55
    Mar 2009
    Southeastern Wisconsin
    Electric Lift
    Here are the pics I promised of the HF electric lift.
    I added traction strips as this lift is not diamond plate.
    Raised with the wheel chock in place
    My RS on the lift. I am going to move the chock further forward as the rear tire is just on the main part of the lift table. The controls come mounted under the front of the table. I moved them up on the deck.
    Doug
    '04 R1150GSA, '96 K1100RS SE, '94 K1100LT, '84 Honda VF700 Interceptor
  11. #56
    Tucson, AZ
    What size angles did you use? How long do they project beyond the bed of the lift? And what did you use to support the front tire between the angles? I am inspired!
  12. #57
    Aug 2008
    Kingston, NH
    I don’t use the front wheel vice. I use the center stand. When I roll the bike onto the lift and put it on the center stand the bike pulls back 11 inches which moves the bike back past the center point of the lift. I fabricated this front wheel stop to extend the stop 11 inches forward so that when the bike pulls back when put on the center stand it is more toward the center of the lift.
    Very cool - I don't use my front stop and as the wheelbase of my wife's ST and my GT differ, this addtion would be great.
    Where did you get all the parts?
    I can't weld so it would be a bolt on activity
    +1
    2009 G450X White
    IBA #35651
    Rogue Moderator
  13. #58
    May 2007
    Raleigh, NC
    I have a Miller Matic 180 autoset MIG welder. I taught a 13 year old girl to weld. With the technology today, ANYONE can weld. Gas, TIG, and Stick take practice and skill, but MIG you can learn to weld decently in an hour.
    '10 R12RT, R90/6
    Suzuki DR 350
  14. #59
    Aug 2004
    Crestview, Florida
    More details on the lift table extension
    Here are some additional notes for the extension project.
    Notes
    A. Main attachment bolts are 7/16 x 1
    B. Newly drilled holes in the lift table. These also match holes drilled in the bottom support drilled about 3/4 in from the end of the angle iron.
    C. This is the original stop that came with the lift. I used it to establish the overall width of the extension.
    D. These supports were cut from 1/8 X 3 flat stock. Welding is not necessary. A 1/4 bolt in end of each piece will work just fine. Most anything will work because youre just trying to keep the pieces from moving around.
    E. I hammered the leading edge of the angle iron over so that it wouldnt damage the tire if I missed as I roll the wheel onto the extension. (not really necessary)
    F. The bottom support is a piece of 1 x 1 x 1/8 angle iron cut to fit between the support rails on the bottom side of the lift. Drill holes to match the width of the extension. See note B
    Gail Kaltz
    1997 GS
  15. #60
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Just listen for the sizzling bacon sound! The only downer is that with MIG, it is easy to make a weak weld, I think part of the education is learnign what is weak & what is strong, again, about an hour time!
