Results 1 to 14 of 14
Thread: Maintenance in the cold
    dstuckmann
    My 12000 mile is due. I'm looking at doing the work myself (first timer) in my unheated Wisconsin garage. Will 35 degree temps mess up critical things like setting valves or the TB sync?
    Thanx
    The metal won't care. Now your frigid fingers might mess up some, but the metal won't care. We see a big difference between 35 degrees and 60 degrees but in the scheme of expansion and contraction and molecular motion the metal doesn't care.
    Rubber gaskets do seem to get a bit cranky. Keep them warm.
    Now 50 below - the metal starts to care.
    Aug 2008
    Kingston, NH
    My wife got me a heater for the garage - I have done service work in it during the winter.
    Doable (not my favorite) just keep an eye on the flamables versus the location of the heater.
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Crow18
    Quote Originally Posted by dstuckmann View Post
    Thanx
    If it's below freezing and somebody offers you a dollar to put your tongue on the cold cylinder head, don't do it.
    I mean, at least hold out for $5.
    Aug 2008
    Kingston, NH
    Quote Originally Posted by Crow18 View Post
    Or if they double dog dare you - it's over
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Midnight Rider 41077's Avatar
    Jul 2004
    Gresham, Oregon
    Get a Heater
    +1 on the heater and something to insulate you from the cold floor.
    Sep 2006
    Quote Originally Posted by Semper_Fi View Post
    I have a Ker-o-Sun heater for early morning cool days in my shop...I just know to NOT mess with flammables on those days or kill the heater...saw that happen once when I was a youngin' and the guys next door were painting a car with laquer near the gas water heater Stuck with me forever!
    Steve Henson
    Jul 2007
    THE BIG SKY
    I have a large heated garage that I keep at 55 degrees when I'm not in it and 68 degrees when I'm working. I have to keep it heated because we have a water holding tank in the garage. I actually spend more $ on oil to heat the garage than I do to heat my house because I run a wood stove in the house 24/7 in the Alaska winter.
    I do have experience working on snogos in -60 degree temps. Got caught out in a cabin by a sudden temperature drop. Was able to get two of 4 machines running. Broke a drive belt just by leaning on it a bit. Nothing works as designed at -60.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    A cheap and easy way to stay warm is to put an IR heat lamp above the workbench. Tools and parts laid out are warm to the touch, and insulated coveralls look after the rest of me.
    Dave
    Dec 2005
    Austin, Minn
    Exclamation Heater
    Maybe you know this,
    but just in case,
    if you use one of those blower heaters that burn kerosene
    like farmers use alot,
    don't use it in a closed garage.
    They were called Kipco or Nipco or something like that.
    The fumes will get you.
    They can produce a lot of heat, but they might kill you.
    They are good for blowing on equipment to heat it up.
    Also, you can get a headache even from short exposure
    in a closed garage,
    Be careful.
    Phil
    2004 K1200GT II 2013 K1300S 2004 K1200GT
    1996 K1100RS 2005 R1200GS 2000 K1200RS
    1995 K75S 2009 HD Road King plus others
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    I've got one of those, I always leave the door open about a foot to compensate.
    Don't try to use a charcoal grill as a heater either. Basically a carbon monoxide generator.
    heater
    The wife just got me an infa-red Heatwise at our local Oreck dealer. Down to 20 degrees last nite, worked this afternooon on the Rockster, at a BALMY 70 degrees, should have done this years ago.
    Eastern KY
    Take a look at an overhead electric heater-there are all sizes/kinds out there. A good place to start is an electrical supply house where they know what does what & before you talk to them you will need to know what the power available in the garage offers you, as in how many amps service. Kerosene is a terrible choice-$$$,bulky/messy and you can buy an electric heater for less!
