Results 1 to 3 of 3
Thread: '09 K1300GT windshield wont raise
    200,000 BMW miles so far
    Dec 2005
    Southern Cal.
    Question '09 K1300GT windshield wont raise
    The windshield lowers just fine, but will not go up. I tried to raise it against a nasty burst of headwind, now it's not working. It acts like I blew a fuse or a circuit breaker.
    My problem is that I don't know where to look for a fuse or breaker in this model.
    Can somebody straighten me out on this?
    TIA
    The K13GT does not have fuses, however it does have a high occurance of failed switch gear, and that is the likely cause of the windshield problem.
    See your dealer.
    Aug 2008
    Kingston, NH
    Quote Originally Posted by limecreek View Post
    See your dealer.
    +1 on that.
    My windshield button did not work up or down.
    Common issue - mine was covered under warranty, while you are at it have them check the part number fo the right side switches as those are under recall also
    2009 G450X White
    IBA #35651
    Rogue Moderator
