Results 1 to 15 of 20
Thread: The New R 1200 GS
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    The New R 1200 GS
    THE 2010 BMW R 1200 GS: Another Chapter Begins
    • 05.11.2009
    • Press Kit
    With the introduction of the new BMW R 1200 GS, BMW Motorrad is writing yet another chapter in the story of its highly successful GS models which, for almost three decades, have been the epitome of the large-capacity grand touring enduro.
    Gallery
    Building upon the former generation of the R 1200 GS, which already offered supreme power and performance as well as a broad range of practical riding qualities for long tours combined with supreme pleasure on winding country and mountain roads, BMW Motorrad is now enhancing this standard to an even higher level. A more powerful engine with extra torque, results in even greater driving dynamics both onroad and offroad.
    The main features of the 2010 BMW R 1200 GS at a glance:
    * New, even more dynamic engine now with two overhead camshafts per cylinder and valves in radial arrangement.
    * Increase in engine output by 5 per cent to 110 hp at 7,750 rpm and maximum torque to 88 lb-ft at 6,000 rpm.
    * Increase in maximum engine speed from 8,000 to 8,500 rpm offers a wider range of useful engine speed.
    * Significantly better acceleration and torque.
    * Electronically controlled exhaust flap for an aggressive muscular sound.
    * Color variants of the R 1200 GS: Alpine White non-metallic, Magma Red non-metallic, Ostra Greymatt metallic, Sapphire Black metallic.
    * Optional extras and accessories tailored to the model with BMW’s usual high level of quality.
    * New additional headlight in LED technology for the R 1200 GS (accessory).
    In its construction principle and fundamental layout, the new flat-twin engine is the same as the Double Overhead Camshaft (DOHC) engine on the BMW HP2 Sport. In its latest generation, the engine has been carefully updated and optimized for the R 1200 GS, tailored to the specific requirements of a grand touring enduro.
    With the 1,170-cc Boxer engine on the former model already ensuring supreme power under all conditions and in all situations, the new R 1200 GS has even more to offer in virtually every respect. Delivering maximum output of 110 hp, increasing top engine speed by 500 to 8,500 rpm, and with an even broader range of engine speed, the new R 1200 GS is even more dynamic, powerful and muscular in terms of both torque and acceleration throughout the entire speed range -- setting the standard once again for the grand touring enduro in terms of riding dynamics.
    New DOHC cylinder heads for even more efficient cylinder charge
    Designed and built at the outset for higher engine speed, the new flat-twin engine in the R 1200 GS, like the engine featured in the BMW HP2 Sport, comes with two overhead, chain-driven camshafts per cylinder. The valves are operated by very light rocker arms able to withstand high engine speeds due to their low weight alone. Radial arrangement of the four valves is accomplished by the compact combustion chambers. Like on the former model, the fuel/air mixture is ignited by two spark plugs (HP2 Sport: one spark plug), while the compression ratio remains at 12.0:1.
    Thanks to efficient knock control, the R 1200 GS is able to run on premium (plus) fuel with an octane rating of 95-98 RON (maximum output is measured at 98 RON). Under certain conditions, there may be a very small loss of torque and a slight increase in fuel consumption as soon as knock control cuts in. On long tours where the rider might be required to use inferior fuel, the engine may also run on 91 RON regular fuel, using specific running data available as special equipment free of charge from the factory.
    Horizontal arrangement of the camshafts in the direction of travel gives the new flat-twin engine two particular technical features: Each camshaft controls one intake and exhaust valve and, due to the radial arrangement of the valves, the cams come with a conical profile. To increase both output and torque, fuel volume has been increased throughout the entire speed range by increasing valve plate diameter over the former models from 1.42–1.54 inches on the intake side and 1.22–1.30 inches on the exhaust side.
    Intake and exhaust timing on the two camshafts has been optimized in particular for supreme power at low and medium engine speeds and for even faster, free-revving engine performance throughout the entire range. To increase the free valve cross-section, valve lift is up by 0.415 inches on the intake and 0.365 inches on the exhaust side to 0.425 inches on both sides. Valve clearance is compensated by light semi-hemispherical shims.
    More power and extra torque throughout the entire speed range
    The existing ratio of bore and stroke of 3.98 : 2.87 inches remains unchanged from the former model, as does the engine’s cubic capacity of 1,170 cc. Other features likewise carried over from the previous engine are the crankshafts and connecting rods as well as their mounts and bearings, while the two new cast-aluminum pistons have been re-designed to match the change in combustion chamber geometry.
    Interacting with the upgraded intake system, now featuring black instead of silver throttle butterfly manifolds as on the former model, measuring 1.97 inches instead of formerly 1.85 inches (HP2 Sport: 52 mm/2.05") opening clearance and with newly designed intake air manifolds and an air filter element with higher volume capability, the engine now develops maximum output of 110 hp at 7,750 rpm and peak torque of 88 lb-ft at 6,000 rpm. An oil cooler ensures stable engine temperatures even when riding to the extreme.
    In all, the modifications to the drivetrain provide a significantly more homogeneous flow of power and torque throughout the entire speed range. In this process of technical development, the engine now features magnesium-colored cylinder head covers with two instead of the former four fastening bolts and come in new, even more dynamic design. A valve cover guard made of aluminum or plastic as well as a chrome-plated aluminum cylinder head cover are available as accessory items.
    Electronically controlled exhaust flap for even more muscular sound
    The exhaust system features two manifolds with the same design, length and diameter as the previous model, while a modified interference pipe regulates the change in vibration conditions in the exhaust system. Featuring an exhaust flap controlled by an electric motor as well as opening and closing cables, the 2010 BMW R 1200 GS provides a particularly throaty boxer sound naturally in full compliance with legal standards. To reduce ram pressure and improve the sound of the engine even further, the rear silencer remains the same in design as on the former model and comes with a completely new interior structure.
    Ideal transmission of power through six-speed gearbox and drive shaft
    Power is transmitted as before by the proven six-speed gearbox with larger bearing diameters and a modified distance between the individual shafts previously changed for the 2008 model year. In the process, the gear ratios were once again changed and the final drive has been modified from 2.82 to 2.91.
    In conjunction with the new, even more powerful engine, there is significantly more torque throughout the entire range of engine speed. The new R 1200 GS also benefits from improved shifting with a power/travel curve for precise gearshift and clear feedback at all times.
    The maintenance-free drive shaft to the rear wheel also remains unchanged, relieving the rider of annoying and time-consuming maintenance requirements, particularly on long tours.
    Proven Suspension and high-performance brakes with Integral ABS
    Like its predecessor, the new R 1200 GS offers an almost perfect synthesis of offroad and onroad riding qualities. As in the past, the stiff and torsionally-resistant suspension, front wheel control with the unique BMW Telelever, and the rear wheel incorporating the BMW Paralever provide first-class and improved riding qualities in combination with the new engine offering even more power and torque.
    In conjunction with optional BMW Motorrad Integral ABS, extremely powerful brakes provide maximum safety even in critical situations. Optimum environmental compatibility is achieved on the new boxer engine through the most advanced exhaust gas management with a fully controlled three-way catalytic converter.
    Enduro ESA – Optional for optimum electronic adjustment of the suspension
    Designed and built for the specific requirements of a grand touring enduro, Enduro ESA Electronic Suspension Adjustment is available on the latest version of the R 1200 GS as an optional extra straight from the factory. Enduro ESA allows adjustment of the suspension under all kinds of riding conditions and with virtually any load level, simply by pressing a button. An important feature of the Enduro ESA is that it offers both an onroad and offroad mode within which the rider, choosing specific settings for the spring base and damping, is able to adjust the suspension even more precisely to specific needs and requirements.
    As usual, Enduro ESA meets the particular requirements of a grand touring enduro by additional electrohydraulic adjustment of the spring base on the front spring strut. When riding offroad, this ensures a far smoother ride without the disadvantages otherwise experienced onroad, such as shorter negative spring travel or greater seat height.
    Optimum ergonomics and even more practical features
    The high-quality, sophisticated handlebar, constructed from a heat-treated aluminum tube, mounted with two asymmetrical clamps, facilitates turning by up to 180 degrees (as on the HP2 Enduro Sport) and may be adjusted in two ergonomically different positions. While the rear handlebar position for riding onroad and in less demanding terrain ensures optimum ergonomics particularly for the shorter rider, the front handlebar position offers advantages when standing up on the machine in rough terrain.
    The hand protectors available as an accessory for the R 1200 GS are installed as standard equipment straight from the factory on the R 1200 GS Adventure. In the process of technically upgrading the successful R 1200 GS models, the instrument cluster has received a newly designed dial. And last but not least, the windshield now comes with larger hand-bolts with even better grip for adjusting its position with greater ease.
    Options and accessories tailored to both the rider and the machine
    As a genuine, fully-fledged systems supplier, BMW Motorrad has developed a wide range of options and accessories for further customization of the new R 1200 GS. One particularly important new feature is the additional headlight in LED technology.
    Options come directly from the factory and are installed during production at the Berlin Plant. Accessories are installed by Authorized BMW Motorcycle Dealers.
    Options
    * Enduro ESA
    * BMW Motorrad Integral ABS (semi-integral, on-demand)
    * RDC
    * ASC
    * Exhaust system chrome-plated
    * Heated HandGrips.
    * Hand protectors
    * Case brackets
    * Cross-spoke wheels
    * On-board computer with oil level warning
    * Low rider’s seat
    * Lowered suspension
    * Anti-theft warning system with remote control
    * LED direction indicators
    * Power reduced to 98 hp
    * 91 RON
    Accessories
    Cases:
    * Vario case
    * Case holder
    * Vario Topcase
    * Topcase fastening elements replacing passenger seat
    * Topcase support
    * Inner bags for Vario case/Topcase
    * Back padding for Vario case/Topcase
    * Watertight tank bag
    * Softbag 2, large, 13.5 gallons
    * Softbag 2, small, 5 gallons
    Styling and Appearance
    * Cylinder head covers chrome-plated
    * Fender, front, in carbon
    * Splashguard, rear, in carbon
    * HP Carbon cover for engine housing
    * Headlight protector (for offroad use only)
    * Cap for Telelever and fork bridge
    * Additional LED headlight
    * Holder for additional headlight
    * LED direction indicators.*
    Sound
    * Akrapovic sports muffler
    Ergonomics and Comfort
    * Windshield, tinted
    * Wide enduro footrests
    * Adjustable footbrake lever
    * Handlebar cross reinforcement
    * Padding for handlebar cross reinforcement
    * Rider’s seat, low (32.3") in Black* or Grey
    * Rider’s seat, Grey
    * Additional power socket
    * Heated HandGrips*
    Navigation and Communication
    * BMW Motorrad Navigator IV
    * Mount for BMW Motorrad Navigator
    * Navigator function bag
    Safety
    * Hand protectors*
    * Spoiler guards, large, for hand protectors
    * Aluminum cylinder head cover protection
    * Plastic cylinder head cover protection
    * Engine protection hoop
    * Enduro aluminum skid plate protection,
    * Frame guard
    * Safety bolts for oil filler manifold
    * Anti-theft warning system with remote control*
    Maintenance and Technical Equipment
    * Reduction in power to 98 hp*
    * Paddock stand
    * On-board toolkit/service kit
    * LED light for on-board power socket, 16.1"
    *Also available as an optional extra from the factory.
    New surface and color design
    The new R 1200 GS demonstrates its enhanced dynamics through new surface design and colors. Ostra Grey matt metallic gives the R 1200 GS a particularly technical touch. Sapphire Black metallic, on the other hand, gives the new R 1200 GS a very masculine look, while the two non-metallic paintwork options in sophisticated Alpine White and brilliant Magma Red highlight the sporting offroad ambitions of the new R 1200 GS.
    2010 BMW R 1200 GS Specifications
    Engine
    Capacity 1,170 cc
    Bore/stroke 3.98/2.87 inches
    Max output 110 hp at 7,750 rpm
    Max torque 88 ft-lb @ 6,000 rpm
    Configuration Flat-twin
    No. of cylinders 2
    Compression ratio/fuel grade 12/S 95-98 RON, max output with 98 RON, optional 91 RON SA
    Valve/gas timing DOHC
    Valves per cylinder 4
    Intake/exhaust valve diameter 1.54/1.30 inches
    Throttle butterfly diameter 1.97 inches
    Fuel supply BMS-K+
    Exhaust management Fully-controlled three-way catalytic converter
    Electrical System
    Alternator (W) 720 W
    Battery (V/Ah) 12/14, maintenance-free
    Headlight (W) H7
    Starter (kW) 1.1
    Transmission/Gearbox
    Clutch Single-plate dry clutch, diameter 7 inches
    Transmission Dog-type six-speed gearshift
    Primary ratio 1.737
    Gear ratios I 2.375
    II 1.696
    III 1.296
    IV 1.065
    V 0.939
    VI 0.848
    Rear-wheel drive Drive shaft
    Final drive ratio 2.91
    Suspension
    Frame Tubular steel frame, load-bearing engine
    Front wheel control BMW Telelever
    Rear wheel control BMW Paralever
    Overall spring travel, front/rear 7.5/7.9 inches
    Castor 4.0 inches
    Wheelbase 59.3 inches
    Steering head angle 64.3 degrees
    Brakes
    Front Dual disc brake, diameter 12 inches
    Rear Single disc brake, diameter 10 inches
    Optional BMW Motorrad Integral ABS
    Wheels
    Cast Cross-spoke
    Front 2.5 x 19
    Rear 4.0 x 17
    Tires
    Front 110/80 R 19
    Rear 150/70 R 17
    Dimensions and Weight
    Length 87 inches
    Width (overall, with mirrors) 37 inches
    Handlebar width (without mirrors) 36.6 inches
    Seat height 33.5/34.3 inches
    Dry weight 448 lbs
    DIN (unladen weight in road trim) 505 lbs
    Max permissible 970 lbs
    Tank capacity 5.28 gallons
    Performance Data
    Acceleration 0–62 mph 3.7 sec
    Top speed 124 +
    Pass the mustard and UP THE REVOLUTION!
    St. Paul Pioneer Press , Minneapolis Star Tribune
    I just copied this stuff to paste to the forum, but M1KA beat me to the punch.
    Interesting stuff.
    Aug 2004
    Fly Over Land
    Bench Racing comes in all sorts of forms doesn't it Paul.
    Sep 2006
    Will it come with a $30 tent?
    Steve Henson
    Aug 2004
    Fly Over Land
    Shhhh! You're going to blow BMW NA's spring marketing promotion
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    But the GS comes with "aggressive, muscular sound" rather than the RT's merely "superior and powerful" exhaust note.
    Does all that electro-mechanical frippery do anything to the power output/management, or is it just over engineered noise modulation with increased cost?
    Naw, couldn't be over engineering.
    Not from the BMW Mother Ship!
    Regardless, I like both of them.
    Inquiring minds need to know.
    '08 BMW R1200RT
    '75 Red R75/6
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Calgary
    So, airhead, oilhead, hexhead..........
    camhead?
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Quote Originally Posted by MCMXCIVRS View Post
    camhead?
    Pointy head
    Registered User I-MAN's Avatar
    Aug 2009
    Beacon, NY
    Does that switchable muffler system include the harley mode?
    BMWMOA #152104
    2014 BMW R1200RT
    harryt11
    Grand Touring Enduro? Has BMW invented another riding category?
    Aug 2004
    Fly Over Land
    Quote Originally Posted by harryt11 View Post
    I've been waiting for someone to pick up on that one. I know you don't post much but try and keep up with the MotherShip, the market is obviously evolving.
    Jan 2008
    Jacksonville, FL
    Thumbs up
    Dual Head (cams, plugs, mounting bolts).
    Ride Safe
    Quote Originally Posted by i-man View Post
    Buell had been using a system like this for a while. Better power etc. not so much for sound, on the Buell anyway.
    Mar 2004
    Northern WV
    Harley riders remove their mufflers, maybe BMW riders will be removing their "flappers"?
    Feb 2006
    Long gone
    No, but here is your logo to paste on your expensive tent.
    Ride Well
    Ride Often
    Ride to
    Ride Well
